An odd problem and cant work it out! *update with pics*
Started by Justin14100, July 15, 2009, 05:38:08 PM
Justin14100
could be that, but it runs fine a lot till a few min a motorway driving, then it starts doing it, so surely the dizzy timing doesnt change?
no it doesn't but if its set wrong, might be better with more/less fuel in it.  Check it anyway.
Justin14100
Quote from: PeteG40 on August 19, 2009, 01:49:11 PM
is there timing marks? How do I check it?
Where is the knock sensor located? Thanks!
you check it with a timing light and the marks on crank pulley.
Knock sensor is on the back of the block - is specific for g40 and is not an efficient knock sensor.
