I've recently bought my first G40 and mine is doing exactly the same thing! im the same, my charger has done probably done about 20k on a 65mm pulley since its last service.
I have the boost return off, but the flying saucer above air box is still attached, with one vacumn coming off it and goin to throttle body and another which has no pipe on it at all, then it has a large pipe on the top.
Mine too also blows out alot of oil out the throttle body, its making a right mes of all pipes and inside of engine bay around the area that it blasts.
I've changed plugs,leads,dizzy cap and rotar arm and it made no difference, it also seems to be an intermittant fault, also when it does do it whilst driving it will not idle smoothly either, kinda rythmic, dropping revs and picking up fast, but not hunting. sometimes it will just conk out all together.
So is it likely to be all the oil in the induction system causing this, as the seals in the charger are on their way out?
