Author Topic: has anyone got any pics of oil pump fitted  (Read 6749 times)
Offline g40chris
« on: June 27, 2009, 10:05:47 pm »
does anyone have any close up pics of a g40 oil pump fitted
i just wanna see if there should be a gap at the end of a pump as mine has a gap at the end of the diagonal pipe on side of pump, just where it joins the bottom end
Offline Dan
Re: has anyone got any pics of oil pump fitted
« Reply #1 on: June 28, 2009, 11:17:04 am »
Do you mean the two leg bracket that holds the oil pump to the block ? It has a slot so it can slide on the oil pump and allow for the adjustment of the chain drive.
Offline g40chris
« Reply #2 on: June 29, 2009, 12:11:16 am »
i cant seem to find this slot on the oil pump
where abouts is the slot?
the gap between the diagonal pipe which goes up the left hand side of the pump and the bottom of the engine is about 2mm. there seems to be some play in the pulley with the chain on as the pulley rattles from side to side
« Reply #3 on: June 29, 2009, 09:16:52 am »
can you take some pics of what you are talking about?  there shouldn't be any play in the pulley that I can remember.
Offline Nick_S
  • 189.6 bhp @ 8psi boost
« Reply #4 on: June 29, 2009, 02:29:25 pm »
Here you go.
Got some more from different angles if needed.
Offline g40chris
« Reply #5 on: June 29, 2009, 06:11:58 pm »
cheers for the picture
as you look at the picture, just to the left of the pulley is a part of the pump which is at a 45 degree angle, im sure this is an oilway, there is a gap at the end of this where it joins to the engine. im sure this is where its losing pressure.
and the pulley moves about 2-3mm towards the pump
Offline NeilG40
« Reply #6 on: June 29, 2009, 07:37:44 pm »
It's been a while since I changed the oil pump on my car but from what I remember the oilway goes through the silver plate on the side of the engine, you can actually see the pipe shape section on the left side in the picture.
Offline g40chris
« Reply #7 on: June 29, 2009, 09:29:36 pm »
thats the one
there is a gap inbetween there and the plate. im sure it shouldnt be like that
Offline Dan
« Reply #8 on: June 29, 2009, 09:36:16 pm »
Ahh, did you use new screws on the oil pump to mount it to the side of the block ? If so, you could well have used ones with a normal head on, that the end plate will stand off.
Offline scotsjohn
« Reply #9 on: June 29, 2009, 09:58:30 pm »
There's a gasket at that end too as you can see in Nick's pic. Check yours is there and hasn't got damaged.
Offline g40chris
« Reply #10 on: June 30, 2009, 07:08:32 am »
i think the screws were the ones originally on the car
i have the gasket that goes between the block and the plate. its an open ended gasket iirc
Offline g40chris
« Reply #11 on: June 30, 2009, 10:41:45 pm »
right been a busy boy again tonight
took timing belt off with plastic plate, took both crank pulleys off so i could take metal plate off the side of engine by the oil pump, dropped oil again, took sump off yet again, there is a definate 2-3mm gap between the oil pump hole and the oil hole in the plate but no adjustment as the plate fits flush and the pump is fixed solid in place. there was no play in the pulley i must have imagined that.
my mate who was with me reckons that the oil pump must be cast and machined wrong as the plate is the original from the car from new. thing is i bought the oil pump from Pitstop developments 2-3 years ago when i was starting to rebuild my engine.
just uploading 2 crappy pics of the gap now
Offline g40chris
« Reply #12 on: June 30, 2009, 10:49:19 pm »
Offline scotsjohn
« Reply #13 on: June 30, 2009, 10:56:23 pm »
You're getting there mate. Just wondered if it's coincidence that the pump stands off it's correct position by a couple of mil and your thinking the pulley was able to move by that amount. If you're sure the pump is set up right then I reckon you should try and find another pump to compare with. If its not right then its not a corner you can afford to bodge.
Offline g40chris
« Reply #14 on: June 30, 2009, 11:19:25 pm »
is there supposed to be a gap in that area where there is a gap in the pictures
aint got another pump to match it against, but i will have to see if i can get my hands on one
