Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Electrical
G40 fuel pump question priming
« previous
next »
Pages: [
1
Go Down
Author
Topic: G40 fuel pump question priming (Read 3376 times)
G40Nik
on:
May 01, 2019, 06:27:13 pm »
Hi I would like to know from fellow G40 drivers when you switch the ignition on does fuel prime up then stop?
Because mine just runs constantly on ignition on not engine running.
Administrators
The CV joint killer
Re: G40 fuel pump question priming
Reply #1 on:
May 02, 2019, 09:03:03 am »
yes when you turn the ignition on it should run for about a second and stop. It'll run constantly if you turn the key again to actually start the engine.
steveo3002
91 golf g60 , 89 gti 16v , 88 breadvan
Reply #2 on:
May 03, 2019, 10:23:18 am »
anyone messed with the fuel pump relay /ecu relay wiring ? ine had been bodged to use an alternate relay
G40Nik
Reply #3 on:
May 06, 2019, 02:15:00 pm »
My car was.GT originally but converted to a With G40 engine .so thinking its something to do with that.
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
Electrical
