Author Topic: fuel pump relays?  (Read 9443 times)
Offline supercharged spaniel
  • GRRRRRRR
fuel pump relays?
« on: January 28, 2009, 11:09:59 pm »
i think it may be a good idea, since they cost very little to put some new fuel pump relays in?  so...where are they exactly?  are they those cube things near the ecu? basically i want someone to talk to me about relays and which ones to change and possibly part numbers so i can order them.
something i havent changed and as they can die its probably worth it...
Offline tdh-syorks
Re: fuel pump relays?
« Reply #1 on: January 29, 2009, 06:35:53 am »
yeah the one of the two relays next to the ecu is it, ones a ecu relay and the other is a fuel pump relay, i changed mine not so long ago. ill try to get the part numbers for you asap
« Reply #2 on: January 29, 2009, 08:39:49 am »
ecu relay about £20, fuel pump on is about £10 i believe
  • GRRRRRRR
« Reply #3 on: January 29, 2009, 08:53:56 pm »
cheers mate that would be great!  is it worth changing them?  do they die from time to time?
« Reply #4 on: January 29, 2009, 09:41:26 pm »
the ecu one has died once on my g and once on gt...
Offline Andy
« Reply #5 on: January 30, 2009, 07:37:14 am »
To be honest, I'd not bother changing them. Buy replacements if you want, and keep them in the glovebox.
The biggest problem I've had is they're fairly exposed to the elements, so you tend to get corroded mank starting to cause continuity issues. I've had pump relays stick on, or just be so corroded they refuse to work. A clean up usually sorts the issue.
  • GRRRRRRR
« Reply #6 on: January 30, 2009, 03:47:32 pm »
yeah i did clean them actually...might just leave them then...or get some at some point but if its unlikely for them just to break there is no rush...cheers for the info lads.
Offline tdh-syorks
« Reply #7 on: January 30, 2009, 08:13:01 pm »
sorry been busy last couple of days, will get you the part numbers tomorrow
LeonBritton123
  • Guest
« Reply #8 on: February 13, 2009, 06:22:15 pm »
321919505A & 867906381
Does anyone know which one is the fuel pump relay?
« Reply #9 on: February 13, 2009, 08:29:53 pm »
the A is a 5 pin ecu relay - the other is the fuel pump one
Offline tdh-syorks
« Reply #10 on: February 14, 2009, 11:14:20 am »
867906381 is the fuel pump relay
