Author Topic: W5DPO replacement  (Read 3939 times)
Offline Stirlitz
    • Ford Cruising
W5DPO replacement
« on: July 13, 2018, 08:34:44 pm »
The W5DPO is GBP 45 apiece over here in Hungary and of course it is for order only... so I'm looking for a replacement spark plug.
I've read through almost every possible topic in Google, tecdoc... all. :)
Now it seems to me that the NGK BPR7EIX is the correct replacement. I'm not trying to be a cheapskate, but that GBP 180 has better place than some overpriced spark plugs.
2 yrs ago it was GBP 15. I don't know what happened. Is that not available...?
So, will I be fine with the  BPR7EIX? :)
Thanks!
Offline Agent47
Re: W5DPO replacement
« Reply #1 on: July 13, 2018, 10:11:34 pm »
eBay number
382135003099
Offline Stirlitz
    • Ford Cruising
« Reply #2 on: July 16, 2018, 01:58:09 pm »
Thanks... I know, but did not want to wait. Wanted it off the shelf.  :-\
« Reply #3 on: July 16, 2018, 05:19:01 pm »
you will be OK with BPR7EIX, in fact some people prefer them to the W5DP0 (which I don't think are available any more anyway, they got replaced with a slightly different part code).
I use BPR8EIX in mine which are equivalent to W4DP0.  Only really necessary if you are running a lot of boost (e.g. turbo instead of supercharger).
Offline Stirlitz
    • Ford Cruising
« Reply #4 on: July 17, 2018, 05:51:25 am »
Thanks!
A read through a gadzillion topics :) ... and even the mentioned BPR7EV went out of production. Good to know there is something to replace with that works well. :)
Offline ereeiz
« Reply #5 on: July 20, 2018, 11:02:20 am »
I wrote a thread on here not long ago about Bosch plugs as I thought I'd found a modern Bosch equivalent. I'll see if I can find what I'm talking about.....
