adjusting tension on toothed belt
Started by busy t, January 27, 2009, 06:50:34 PM
busy t
i recently fitted a new toothed belt and adjusted the supercharger to max and it is still way loose, it hits on the engine mount on idle its soo loose.
i had the car up and was looking at the alternator and can only see one bolt and that has no way of adjusting the position of the alternator, do i need to take the charger off? if not...how do i give it more tension??
Dan
Sure you have the right length belt ? Alternator in correct position (althogh there technically can only be one)
no there is some adjustment in the alternator - samg40 had that problem with his
pete
Dan
There can't be (only clearance in the screw holes), there shouldn't be an adjuster on the bottom of the alternator.
Wonder where sam got his alternator; was he having trouble with belt lenght too maybe? The G's adjustment's purely on the charger.
samg40
I know there shouldnt be but there is. Basically the studs on my downpipe snapped so I had to have my manifold off, so off came the the alternator and the charger. Now before I started the charger belt was tensioned no problem. Took it all apart and put it back together and the belt wouldnt tighten. On the advice of Andy I took the charger off and repositioned the alternator, basically pushing it in a position to make the maximum difference to the tension. Put the belt on and tbh it's never been on so tight. I've had the alternator and charger off a fair few times and never had that issue before, Pete and I were stumped at the time.
correct, i've just bolted an alternator on my g and you can push it down an extra 4-5mm.
đuro
Quote from: Dan on January 27, 2009, 07:48:00 PM
How do y. mean there shouldn't be any adjuster !? I hv it and alternator can be mooved for some 3-4 cm up and down. But hv samo problem with tooth belt - it is to long.
Dan
Ah yes, i see what you mean now. The top bolt is something like an M8 x something long and the hole in the alternator is bigger allowing it to move up and down a few mm, by pivoting the bottom mount.
busy t
so do i have to remove the charger to get to the other alternator mounting point?
đuro
Quote from: busy t on January 29, 2009, 01:28:11 AM
No, y. can remove it down without moveing charger
