diagnostic reader help
Started by steveo3002, June 17, 2018, 05:54:00 PM
I don't think that list from that other thread has the correct numbers any more.  They look like a conversion to utf-8 characters gone wrong.  It's a really old post from 2008 and we've changed forum software since then which involved importing all the old data, some character set conversion errors happened.
steveo3002
update...replacement afm with anti tamper seals intact...still same
bad idle and no hot starts , drives normal ish anything above idle
steveo3002
updated info
bad idle,bit bumpy pop pop sound  and refuses to start hot - between 3-20 mins , will start with bts undone , drives fairly okay above idle
a few things ive tried /done
timing set as per the book
air bypass mixtured tired various settings ...its set to 14.1 afr via a wideband gauge at the moment
tried another dizzy /cap/arm
tried another coil
correct plugs fitted
earths good
tried another tps
no obvious air leaks + charcoal can deleted
correct 3 bar pump fitted
new genuine blue sender plus tried others i had laying around
spare set of used inj tried with new o rings
spare afm tried
blocked the isv at the tb elbow- no change in running
engine basics should be fine as ive had the car driving for 2 years on a carb ..ive not touched the internals since
still waiting on a ecu to try...them im pretty much out of ideas
Quotebit bumpy pop pop sound
do you mean it's misfiring?
steveo3002
#34
i guess it must be an intermitant mis , note changes if i pull the plug lead so its not a complete misfire
drives normal enough no hint of misfire or jekryness
pretty much sounds like a cross between del boys three wheeler and a muscle car with the lumpy idle
see what happens when the ecu turns up...if i had to say whats wrong its like when entering set up mode with the bts off , its ignoring it , timing and mixture out , but its not ?    wideband holds a steady reading , not sure it would if bad misfire ?
steveo3002
#35
right
just the same on spare ecu
tried spare tb , fpr and ran some new wires all the way from blue sender to ecu
no change..
have also fitted o2 sensor now
cant think of anything else to try ?  rebuild loom or mess with afm spring
at a bit of a loss really.
have you tried a new set of plugs and leads?
steveo3002
yeah new correct plugs in it , tried leads etc
not sure if this is any progress or not...
i took the lid off the afm and with my finger pushed the slider around a bit more while running , sounds much nice ,and the other way sounds worse , so thinking maybe it needs a tweak to richen it ??
or any other ideas why it would be lean at idle
steveo3002
any ideas on the tools needed to check fuel pressure ?
ereeiz
Get a fuel pressure gauge and fit it in your fuel line before the pipe enters the rail, this should give you an idea.
there's a test point on the end of the fuel rail under the wiring connector.  Take the small bolt out of it and push a pipe over it (with a jubilee clip to seal it), run this to a gauge with a max of at least 50psi.
steveo3002
#41
ah yeah...like  6mm or so bolt?  would it always be 3 bar or only at max revs?
will look for a gauge on the ebay
yeah it's a small bolt.
it's a 45psi pressure regulator but the running pressure is governed by vacuum and boost.  If its a GT then obviously you'll never see boost so shouldn't go much over 45psi at all.
NealPeal
Did you get the pressure tested, any luck in general?
I lost a load of fuel from the rail when I was plumbing my new £14 oil/fuel pressure tester in, but straight after, all my lumpy running problems seem to have gone. Coincidence being I'd replaced an oil pressure tester at the same time.. I think I've had some dusty old petrol go through the pump, and the pipe-burst has cleared some rubbish out, or bubbles out, but mine does seem *crack on* just over the course of a dinnertime.. Everytime I've run it out of petrol a bleeding has fixed it, I'm pretty sure now....
And I found the oil leak..! After taking the engine 1/3 out it was the camshaft sprocket-end seal in tatters...!
Cool
Neal
steveo3002
havent looked at the pressure yet(what gauge did you use)
so tonight ..messed with the afm to make it a little richer , seems slightly better but that wasnt the fault
as it stands now
bumpy idle
blue temp sender undone sweetens it alot /almost fine?
o2 sensor connected = terrible had to undo it
