Wheel arch and sill protection
Started by AxA, September 07, 2017, 05:09:31 PM
AxA
Hello,
Is it possible for someone to let me know what size and type of rivets are required to attach the plastic wheel arch protectors to body, same info required for the sill protectors if poss. Just preparing for restoration. Be brilliant if anyone knew exactly where to purchase them from.
Many thanks,
Neil
Jester
Probably not much help but the arches were plastic push type ones that go flush (36 of them), I've read you can still get them from VW but I don't have the part number.
sleag40
The arch and sill trims are held on with black pop rivets, still available at VW a couple of years ago. I'll have a look in my receipt folder and see if I can find the part number.
ereeiz
WHEEL ARCH:
http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/PO/year/1991/drive_standart/120/hg_ug/821/subcategory/63000/part_id/3706192/lang/e
14   N 0385491
spreader rivet   8X12
Number 14 on the diagram
SILL PROTECTOR:
http://www.oemepc.com/vw/part_single/catalog/vw/markt/RDW/modell/PO/year/1991/drive_standart/120/hg_ug/853/subcategory/72000/part_id/3694017/lang/e
12   N 90634901
pop rivet   4X14
Number 12 on the diagram.
For the wheel arch kit:
17   N 90634901
pop rivet   4X14
Same part number as above. Number 17 on the diagram.
AxA
All replies much appreciated. I sourced some original VW rivets from the supplied part numbers.
Neil
