Clutch pedal donking
Started by Alex, May 27, 2017, 08:06:56 PM
Alex
It's just started doing this. Doesn't seem to be causing any actual issues but concerned that it might.
https://youtu.be/IXmC2gara2c
Standard clutch, manual cable adjustment and one of those metal ends on the pedal end of the cable.
You can feel the clonk through the pedal, but it doesn't feel like there's any extra resistance before it clonks, it's just a noise it makes at the top of the downward stroke, never on the way back up. And it doesn't do this all the time.
Any ideas?
ereeiz
GR40
If I remember correctly this noice means the rubber part on the clutch cable that connects to the firewall has destroyed itself and now moves around. Take the clutch cable out and inspect. If the rubber disintegrates you will be left with a couple of cm of play in your clutch cable and that is enough to make you unable to shift gears (clutch will not be pressed to allow the gear change). It has happened to me while in motion! Not a pleasant thing having to revmatch in traffic or having to start the car with first gear engaged just to move.
Alex
Quote from: GR40 on May 28, 2017, 09:51:41 AM
Cool, I'll have a look. Thanks!
@ereeiz I knew someone would say that  ;D
