G40 Ball joints
Started by Ian Johnson, March 01, 2017, 05:55:25 PM
Ian Johnson
Does anyone know the size of the ball joints on front arms....need to replace as I don't want to to get rid of the rose joints for new rubber bushed ones that can only be purchased nowadays.
Has anyone pressed out old and pressed in new ones ?
https://www.polog40.co.uk/forum/index.php/topic,8285.0.html
I've got a few sets of these in stock Ian, replace the stock rose joint and uses the standard 17mm ball joint.
You'll need to enlarge the TCA mounting hole to 1/2" bore (circa 10.5mm stock)
Allow some camber adjustment with an ARB, more if you have a full stage 3 frame.
Ian Johnson
Hi Pete
Are these ok to fitted to stock chassis apart from hole enlargement, still running the cup top mounts so plenty of adjustment for camber/castor.
kwijibo_coupe
Didn't realise you still had these in stock Pete.
How much for a set?
Think I've got 2 pairs in stock, £225+postage (£15 UK Mainland)
Ian - Yes for sure, I would recommend replacing the standard rubber bushes (as supplied) with nylon counter parts (I sell these too).
Coupled with a set of adjustable top mounts you'll be able to perfect your camber, castor and KPI.
