Author Topic: Lots of g40 parts - heads / bottom ends / cams / chargers / intercooler  (Read 8074 times)
Offline grungeisdead
Open to offers, collection from Leeds, can post
G40 Front Shock Inserts - Used - sold
G40 Cam & Pulley - 50
Polo G40 Inlet Manifolds x 2 - 35 each
G40 Polo Mk2 Standard Intercooler refurbed - 175 plus used one 125
Polo G40 Servo - 20
GT Head rebuilt with double-valve springs, sodium filled valves around 10k ago. - sold
Big valve head - 30mm/37mm - SOLD
Eaton M45 charger, pullies, belt, brackets & chip - 350
Crane cams 268/268 cam - SOLD
Schrick 268/268 - 80 needs repair to dizzy end, has cracked
G40 Exhaust Manifolds - SOLD
Dewedged G40 Throttle Body - SOLD
G40 Looms - SOLD
G40 ecu's - 100
G40 clutch and pressure plate - sold
G40 injectors - 30 for 4 or 10 each
GT injectors - sold
G40 TCA's - require new inner ARB bushes, ideal for g-ladersiete bushes. - 70
1W build - £1000
1W diesel bottom end
1W engine block with oil squirters (+ 2 spare squirters)
Block has not been bored out to 77mm - expect £100 cost for this
1W crankshaft (low miles - no wear)
Accralite 1473 77mm forged pistons - (BNIB)
(Part no 9905 x77 -  Ring widths, 1.5mm/1.5mm/2.5mm)
Rods
Complete bearing set (brand new) (big end and main bearings)
Loads of gaskets including each end of the crank
Oil Pump
VAG water pump
Sump
« Last Edit: January 22, 2018, 07:55:34 pm by grungeisdead »
Offline Nikolia
Re: Lots of g40 parts - heads / bottom ends / cams / chargers / intercooler
« Reply #1 on: January 15, 2017, 09:09:12 am »
Are the PY blocks still for sale?
Cheers.
Offline Nikolia
« Reply #2 on: January 15, 2017, 09:17:11 am »
Interested in either the standard block with the melted piston or the bored and honed block if either are still available?
Cheers.
Offline ereeiz
« Reply #3 on: January 16, 2017, 12:23:17 pm »
Still got the clutch? How many miles / how worn is it?
Offline matthg40
« Reply #4 on: January 22, 2017, 05:40:10 am »
Have you had any interest in the eaton?
« Reply #5 on: January 24, 2017, 02:38:39 pm »
still got it, looks decent. will dig it out this week
« Reply #6 on: January 24, 2017, 02:39:01 pm »
yourself and another 2 guys but noones come up with the reddies yet
Offline matthg40
« Reply #7 on: January 25, 2017, 02:26:13 pm »
Is everything included to get the eaton running?ive been after one for a while,Ive got 280 in my car fund and can find the rest if everything is there to get it going my friend
Offline ereeiz
« Reply #8 on: February 09, 2017, 12:10:52 pm »
I'll have the clutch kit mate, will PM you now.
Offline Mk1james
Hi, is the big valve head still for sale?
Thanks!
Offline Shamas85
Hi,
Do you still have either or both of the standard intercoolers for sale?
Hey buddy only standard intercooler I have is a Mk2 g40 item not mk3
Bvh is still here james
Offline ereeiz
Bought a new clutch in the end. Fitting it today, joy of joys...
Eaton kit; which one is it? Dare I ask, is it reliable?
Offline Shamas85
Doh! Ok mate, no worries.
Never ran it, looks like a custom job, with a PSD eaton chip.
Eatons should be reliable, sealed units so should do 100k without servicing. Too noisy for me so I've never had the inclination to use it
