mk2 coupe g40
Started by tadpole1987, March 27, 2016, 09:44:36 PM
tadpole1987
Hi people im building a mk2 coupe g40 and im having trouble with the fueling do I need to change the interior loom as there is no wires for the exterior fuel pump and there is no intank pump so would I need to change the tank for a g40 tank with intank pump
RyanC
You can uses the same tank just blank off the feed and return at the bottom.
Would be easier to just swap the loom for a g40 loom or just take the bits you need from it as the rear light plugs will be differant possibly, but if you have a wiring diagram and basic electrical skills you can work out and wire in the pumps yourself but it's will probs be cheaper to find a g40 loom and a lot less hassle
