Technical => Electrical => Topic started by: tadpole1987 on March 27, 2016, 09:44:36 pm
Hi people im building a mk2 coupe g40 and im having trouble with the fueling do I need to change the interior loom as there is no wires for the exterior fuel pump and there is no intank pump so would I need to change the tank for a g40 tank with intank pump
You can uses the same tank just blank off the feed and return at the bottom.
Would be easier to just swap the loom for a g40 loom or just take the bits you need from it as the rear light plugs will be differant possibly, but if you have a wiring diagram and basic electrical skills you can work out and wire in the pumps yourself but it's will probs be cheaper to find a g40 loom and a lot less hassle
