Author Topic: Polo 1991 Steilheck  (Read 8190 times)
Offline alexander olsen
Polo 1991 Steilheck
« on: October 27, 2015, 09:34:17 pm »
This is my Polo, have been building now end then for 3-4 years..
Re: Polo 1991 Steilheck
« Reply #1 on: October 28, 2015, 02:06:22 pm »
Looks interesting, what's the spec?
« Reply #2 on: October 28, 2015, 09:49:11 pm »
Forged pistons Wiseco (oversize,1299cc), H profil conrods K1, balanced bottom, Oil cooling nozzle (Piston bottom cooling),
chromoly flywheel, 300hp\300nm clutch, K-data injection ("mega squirt") , homemade inlet manifold. dont remember more..
« Last Edit: April 11, 2016, 10:34:19 pm by alexander olsen »
« Reply #3 on: April 11, 2016, 10:52:16 pm »
Update.
« Reply #4 on: May 05, 2016, 09:57:55 pm »
Update:
99% finish with exhaust,
Fuelrail welded up and drilled,
Throttle wire bracket made and welded....
Thanks for watching!
Alex
« Reply #5 on: May 06, 2016, 07:06:49 am »
Nice progress - the angle of your fuel injectors looks very steep?
« Reply #6 on: May 06, 2016, 08:32:01 am »
The angle is 45 degrees. No space to have more..
Take a look on this page, I did some reading about this angle problem before I made the inlet.
http://www.hotrod.com/how-to/engine/hrdp-0704-pitstop-fuel-injector-location/
« Last Edit: May 06, 2016, 09:02:52 am by alexander olsen »
Offline polo classic
« Reply #7 on: May 06, 2016, 11:17:08 am »
I have been following you on Insta Melkebart
« Reply #8 on: May 06, 2016, 11:42:57 am »
I had to chuckle at the irony of a hotrod magazine talking about EFI... still times change.
I think you'l struggle with cold start personally, could you not mount them on the underside? A change of injector type might also be beneficial, assuming these are single pintle EV-1?
Fuel pressure and spray pattern are critical if you're going to avoid fuel droplet formation, and the poor AFR/idle quality associated with it.
Nice project though  8)
« Reply #9 on: May 06, 2016, 12:06:41 pm »
I dont know  :) This is the first car I'm building, so I guess time will show if it works or not :D
Ev14 with 4 or 5 holes.. QSP fuel pump, think it will have 3 bar of fuel pressure, using an-6 hoses..
Alex
« Last Edit: May 06, 2016, 12:10:20 pm by alexander olsen »
« Reply #10 on: May 06, 2016, 07:49:31 pm »
Do you ?  ;) Whats your name on Instagram ?
« Reply #11 on: May 09, 2016, 08:37:24 am »
Frodeguld
« Reply #12 on: May 10, 2016, 09:12:13 pm »
« Reply #13 on: May 10, 2016, 09:14:56 pm »
Began to make a oil catch tank today.
Alex
