Author Topic: Drop of presure  (Read 4324 times)
Offline Alexiskayak_7
Drop of presure
« on: January 06, 2009, 10:34:35 am »
Well...I have a totally stock g...  When i placed a boost gauge i had 0.4@3500-4500 and 0.65@6000rpm...
After i sprayed ptfe at the charger (i spayed more than i have to) it was showing 0.5-0.55@6000rpm...
I have NO boost leak ( i triple checked al my boost hoses...
How can i solve the probem?
Offline TomG401991
Re: Drop of presure
« Reply #1 on: January 25, 2009, 01:51:19 pm »
is you boost gauge a good quality one
and check that the hose you tapped vacume from isnt leaking and the hose to your gauge isnt leaking
Offline scotsjohn
Re: Drop of presure
« Reply #2 on: January 25, 2009, 05:10:26 pm »
Are these readings taken on the road or standing still ? Try a reading at over  5000rpm in third gear; you should see about 0.7bar from a stock charger in good nick.
Re: Drop of presure
« Reply #3 on: January 28, 2009, 02:32:26 pm »
These readings are taken while i was on road...
My problem is that my boost was ok before spraying ptfe... After i sprayed ptfe i had less boost presure...
I sprayed 2-3 bursts more than i had to...
Also the hose that is from the down side before CO pontetiometer is on position and it's not cutted...
Re: Drop of presure
« Reply #4 on: January 28, 2009, 02:37:18 pm »
what ptfe grease are you using?
Re: Drop of presure
« Reply #5 on: January 29, 2009, 03:34:51 pm »
Wurth's PTFE spray grease...
Re: Drop of presure
« Reply #6 on: January 29, 2009, 03:35:41 pm »
wouldn't have thought it would drop
sorry cant help more
Offline tdh-syorks
Re: Drop of presure
« Reply #7 on: January 29, 2009, 04:54:44 pm »
a worn or torn apex seal maybe????? ??? ???
