Author Topic: eaton toothed pulleys - which ones?  (Read 1430 times)
Offline sackmcgannay
« on: February 01, 2015, 03:27:48 pm »
going to put an eaton m45 on my g40 - ive already got a tothed pulley kit for the g laser - does this swap over to the eaton or do i need to buy new  bits?
thanks
Offline AlfIE40
Re: eaton toothed pulleys - which ones?
« Reply #1 on: February 01, 2015, 03:43:58 pm »
Pretty sure the eatons come with a toothed pulley mate. Some one more knowledgable will correct me if I'm wrong though.
Offline GR40
« Reply #2 on: February 02, 2015, 05:54:05 pm »
NO they come with a multi v pulley. You can get multi v pulleys for the crank and alternator out of a polo 6n if you want to fit it with a multi v blelt  or you will have to make a toothed pulley for the charger! I have seen a couple of custom made before but don't know if someone makes a kit or a specific eaton one.
Offline scully
« Reply #3 on: February 03, 2015, 05:38:10 pm »
Are the polo 6n pulleys 5pk or 6pk pulleys?
Offline GR40
« Reply #4 on: February 04, 2015, 12:57:33 am »
Mine where 6pk pulleys but I fitted a 5pk belt cause the 6 pk belt was rubbing on the chassis. Works fine with the 5pk. If tightened correctly you will get no slipping.
