Technical => Superchargers / G-Lader => Topic started by: sackmcgannay on February 01, 2015, 03:27:48 pm
going to put an eaton m45 on my g40 - ive already got a tothed pulley kit for the g laser - does this swap over to the eaton or do i need to buy new bits?
thanks
Pretty sure the eatons come with a toothed pulley mate. Some one more knowledgable will correct me if I'm wrong though.
NO they come with a multi v pulley. You can get multi v pulleys for the crank and alternator out of a polo 6n if you want to fit it with a multi v blelt or you will have to make a toothed pulley for the charger! I have seen a couple of custom made before but don't know if someone makes a kit or a specific eaton one.
Are the polo 6n pulleys 5pk or 6pk pulleys?
Mine where 6pk pulleys but I fitted a 5pk belt cause the 6 pk belt was rubbing on the chassis. Works fine with the 5pk. If tightened correctly you will get no slipping.
