Headbolts and Cam Bearing Torque Figures
Started by Robin, January 01, 2009, 09:32:26 PM
Robin
I ain't got a haynes manual as i am too tight to buy one so can anyone tell me the torque figures for the headbolts and camshaft caps please.
Also what is the sequence for the headbolts? I usually start from the middle.
Fred
Hi Robin,
           Taken from my Haynes Manual.
Torque Wrench Settings                  Nm                              ibf ft
Cylinder Head Bolts (engine cold):
Stage1.........................................40                              30
Stage2.........................................60                              44
Stage3 (angle tighten)....................+ One half-turn (180*), OR + two quarter-turns (2X90*)
Camshaft Bearing Cap Nuts
Stage1........................................6                                 4
Stage2 (angle tighten)...................+ one quarter-turn (90*)
Head bolt sequence
Fred
ps, the 180 in brackets is degree`s as you will know but i didn`t know how to do the little degree circle so used the star instead.
Hope that all helps Robin and if you need owt else from Manual then let me know and i`ll scan it on me flatbed scanner for you. (probably naughty)
Regards, Fred.
