Author Topic: Trabant G40  (Read 30529 times)
Offline Hunor
Trabant G40
« on: January 04, 2015, 11:09:29 pm »
Hello guys, in advance I apologie for my english, I'm from Transilvania.
Last summer I have started a project: to swap the original 1.1 VW engine with a 1.3 G40 engine in my Trabant, and to make it  turbocharged. In romania we don't have G40 experts and not even G40s, I barely found an engine donor (don't start throwing rocks, I didn took apart a good G40), so I need to rely only on online documentaton, so imagine how happy I was that I found this forum.
At first I would like to start with presenting my car: I'm working on it for la last 5 years. In this time i have changed the 4 speed gearbox for a 5 speed (code WW0 from a Golf1), servo brake, FK inoxline adjustable suspension, 50mm stainless steel exhaust, Opel Corsa Sport ventilated front disc brakes, and more others.
Now comes the hard part the swap. I have finished the exhaust manifold and the downpipe, I'm using a k03 turbo (the cold part and the midel part from a Skoda 1.8t, the hot part from an Audi). I have the original wiring form the G40, the stock engine, and I think the original gearbox. The questions ar the following:
1. What should I change in the wiring to make the conversion from the G-lader to the turbo?
2. I need to change the map sensor? I'm planing on running on 0.7-0.8bar boost at the beginning with the original chip, then go up to 1 bar when I can get a new chip.
3. For this configuration the original intercooler is enough or I need a biger?
Thx in advance for the help, and if you are interested I will keep you posted on the project.
In the pictures I use the original 1.1 engine as a dummy, it's easier.
« Last Edit: January 04, 2015, 11:11:08 pm by Hunor »
Re: Trabant G40
« Reply #1 on: January 05, 2015, 09:11:44 am »
hello! Welcome to the forum.
It's nice to see a Trabant G40 on here, pretty sure you're the first member.  I've seen pictures of them before.  I have driven a Trabant with the older 2-stroke engine in it, it's an experience, I imagine it must be pretty scary with even a standard G40 engine in.
For wiring with the turbo the only thing I changed was removing the full throttle switch and using a pressure sensor set at around 6psi.  This is because with the turbo you can still get quote a lot of boost when not on full throttle.  I think there will be information on this in the engine or wiring sections on here.  You will need an ECU chip to suit though.
With 1 bar or less there's no need to change the map sensor. It's only if you want more than 1 bar that it needs swapping for a higher rated one.
Offline SamG40
  • Take.... on.... me....
Re: Trabant G40
« Reply #2 on: January 05, 2015, 12:27:43 pm »
Awesome! Welcome to the forum. Please keep us updated with the progress. Have a look through the turbo section here, there is loads of good info in there.
Re: Trabant G40
« Reply #3 on: January 05, 2015, 01:22:41 pm »
Excellent project!
I'd recommend a bigger intercooler, but I think if you just go with whatever you can make fit it'd be fine! You'll also want to change the G40 camshaft for a different one - a 3F (Polo GT) camshaft is a better place to start, or ideally a 254° or 268° aftermarket camshaft from Piper, Schrick etc.
Offline Hunor
Re: Trabant G40
« Reply #4 on: January 05, 2015, 05:41:12 pm »
From which car can I use the pressure sensor? because I couldn't finde an universal one. Until I finde someone who can make a costum chip, the stock one will work with a pressure sensor at 6psi, an 0.8 bar boost, the original map sensor, and a BOV (i dont know yet what kind I will buy)?
About the camshaft... here in romania you can't find to easy a Polo GT so for a while it stays stock (and because its a buget build i can't afford to give 2-300euro for an aftermarket one)
With the original internals what is the highest boost that I can run in a daily driven car?
For the oil cooling what is better, water or aer cooling?
« Last Edit: January 05, 2015, 05:42:53 pm by Hunor »
Offline Hunor
Re: Trabant G40
« Reply #5 on: January 20, 2015, 05:01:48 pm »
Hey guys, can you answer the uper questions? And I would add a nother one: insted of the GT f3 camshaft can I use one from a golf 3 1.6 ABU?
Re: Trabant G40
« Reply #6 on: January 21, 2015, 09:24:36 am »
For a pressure switch, the type used with water injection kits work well (Aquamist etc...).  I got mine from this place:
http://www.pvl.co.uk/no-nc-contact-pressure-switches.html
You'll probably find stuff on ebay too.
As for the cam & a remap, it's not going to work very well using the standard ones.  It'd be better staying with the G-Lader if you're not going to change those things.  The characteristics of the standard cam don't suit a turbo.  A GT cam is a compromise to save money, ideally buy a shrick 268/268.
Offline xrrich
Re: Trabant G40
« Reply #7 on: January 21, 2015, 12:47:17 pm »
I have a brand new PVL pressure switch for sale of you want it
PVL prices are always going up!
Already set to 6psi
Let me know if you want it I can find it out
Offline Hunor
Re: Trabant G40
« Reply #8 on: January 21, 2015, 06:43:51 pm »
I wrote a mail to PPP, and soon I'll get on offer for a chip (made for the specs that my engine have) and for the shipping price to Romania.
I already orderd a pressure swich from the ebay. And I'm planing on buying a new cam but i don't have yet the founds for it, thats why I asked about the cam from the ABU, because I have one home.
Re: Trabant G40
« Reply #9 on: January 22, 2015, 09:15:38 am »
I've never tried one but I think an ABU cam should work better than a g40 one.
Re: Trabant G40
« Reply #10 on: January 22, 2015, 11:52:31 am »
ABU is fairly close to 3F in duration and lift, so might work okay. An aftermarket 268° camshaft would be even better.
What variant of K03 are you using? If it's one of the largest ones, then an ABU or 3F cam might work well.
Offline Hunor
Re: Trabant G40
« Reply #11 on: January 22, 2015, 12:35:41 pm »
I just talked to soneone who has majured an F3 cam and an ABU cam, and they ar the same. So the cam problem is fixed for now :D
I'm using a combined K03, the air intake part and the middel part (with the turbines) are from a Skoda 1.8t 150bhp, and the exaust part is from an audi K03. They fit together perfectly.
Now I'm waiting for an answer from PPP.
« Last Edit: January 22, 2015, 12:38:10 pm by Hunor »
Re: Trabant G40
« Reply #12 on: January 22, 2015, 03:03:25 pm »
an ABU cam and a 3F (as in GT) cam?  Fairly sure they're not the same.
Re: Trabant G40
« Reply #13 on: January 22, 2015, 04:31:04 pm »
ABU and 3F are slightly different according to my info:
http://www.clubpolo.co.uk/forum/index.php?showtopic=235735&p=2166614
You have an email back from PPP Hunor. ;) For some reason your replies had gone into our spam folder.
Offline Hunor
Re: Trabant G40
« Reply #14 on: January 23, 2015, 05:47:02 pm »
I've got the mail, I like the offer, I sent a reply with some questions. Probably next month I'll order the chip, till then I need new and bigger injectors :D If the chip is for 250cc injectors can I put biger ones in like from a Golf mk4 1.8t, 317cc? You guys throw around with G60 injectors and GT parts like you could find them at any corner :P In my whole life I seen only one G60, and I can count all of them in Romania on one hand.
