Trabant G40
Started by Hunor, January 04, 2015, 11:09:29 PM
Hunor
Hello guys, in advance I apologie for my english, I'm from Transilvania.
Last summer I have started a project: to swap the original 1.1 VW engine with a 1.3 G40 engine in my Trabant, and to make it  turbocharged. In romania we don't have G40 experts and not even G40s, I barely found an engine donor (don't start throwing rocks, I didn took apart a good G40), so I need to rely only on online documentaton, so imagine how happy I was that I found this forum.
At first I would like to start with presenting my car: I'm working on it for la last 5 years. In this time i have changed the 4 speed gearbox for a 5 speed (code WW0 from a Golf1), servo brake, FK inoxline adjustable suspension, 50mm stainless steel exhaust, Opel Corsa Sport ventilated front disc brakes, and more others.
Now comes the hard part the swap. I have finished the exhaust manifold and the downpipe, I'm using a k03 turbo (the cold part and the midel part from a Skoda 1.8t, the hot part from an Audi). I have the original wiring form the G40, the stock engine, and I think the original gearbox. The questions ar the following:
1. What should I change in the wiring to make the conversion from the G-lader to the turbo?
2. I need to change the map sensor? I'm planing on running on 0.7-0.8bar boost at the beginning with the original chip, then go up to 1 bar when I can get a new chip.
3. For this configuration the original intercooler is enough or I need a biger?
Thx in advance for the help, and if you are interested I will keep you posted on the project.
In the pictures I use the original 1.1 engine as a dummy, it's easier.
hello! Welcome to the forum.
It's nice to see a Trabant G40 on here, pretty sure you're the first member.  I've seen pictures of them before.  I have driven a Trabant with the older 2-stroke engine in it, it's an experience, I imagine it must be pretty scary with even a standard G40 engine in.
For wiring with the turbo the only thing I changed was removing the full throttle switch and using a pressure sensor set at around 6psi.  This is because with the turbo you can still get quote a lot of boost when not on full throttle.  I think there will be information on this in the engine or wiring sections on here.  You will need an ECU chip to suit though.
With 1 bar or less there's no need to change the map sensor. It's only if you want more than 1 bar that it needs swapping for a higher rated one.
samg40
Awesome! Welcome to the forum. Please keep us updated with the progress. Have a look through the turbo section here, there is loads of good info in there.
Excellent project!
I'd recommend a bigger intercooler, but I think if you just go with whatever you can make fit it'd be fine! You'll also want to change the G40 camshaft for a different one - a 3F (Polo GT) camshaft is a better place to start, or ideally a 254° or 268° aftermarket camshaft from Piper, Schrick etc.
Hunor
#4
From which car can I use the pressure sensor? because I couldn't finde an universal one. Until I finde someone who can make a costum chip, the stock one will work with a pressure sensor at 6psi, an 0.8 bar boost, the original map sensor, and a BOV (i dont know yet what kind I will buy)?
About the camshaft... here in romania you can't find to easy a Polo GT so for a while it stays stock (and because its a buget build i can't afford to give 2-300euro for an aftermarket one)
With the original internals what is the highest boost that I can run in a daily driven car?
For the oil cooling what is better, water or aer cooling?
Hunor
Hey guys, can you answer the uper questions? And I would add a nother one: insted of the GT f3 camshaft can I use one from a golf 3 1.6 ABU?
For a pressure switch, the type used with water injection kits work well (Aquamist etc...).  I got mine from this place:
http://www.pvl.co.uk/no-nc-contact-pressure-switches.html
You'll probably find stuff on ebay too.
As for the cam & a remap, it's not going to work very well using the standard ones.  It'd be better staying with the G-Lader if you're not going to change those things.  The characteristics of the standard cam don't suit a turbo.  A GT cam is a compromise to save money, ideally buy a shrick 268/268.
xrrich
I have a brand new PVL pressure switch for sale of you want it
PVL prices are always going up!
Already set to 6psi
Let me know if you want it I can find it out
Hunor
I wrote a mail to PPP, and soon I'll get on offer for a chip (made for the specs that my engine have) and for the shipping price to Romania.
I already orderd a pressure swich from the ebay. And I'm planing on buying a new cam but i don't have yet the founds for it, thats why I asked about the cam from the ABU, because I have one home.
I've never tried one but I think an ABU cam should work better than a g40 one.
ABU is fairly close to 3F in duration and lift, so might work okay. An aftermarket 268° camshaft would be even better.
What variant of K03 are you using? If it's one of the largest ones, then an ABU or 3F cam might work well.
Hunor
#11
I just talked to soneone who has majured an F3 cam and an ABU cam, and they ar the same. So the cam problem is fixed for now :D
I'm using a combined K03, the air intake part and the middel part (with the turbines) are from a Skoda 1.8t 150bhp, and the exaust part is from an audi K03. They fit together perfectly.
Now I'm waiting for an answer from PPP.
an ABU cam and a 3F (as in GT) cam?  Fairly sure they're not the same.
ABU and 3F are slightly different according to my info:
http://www.clubpolo.co.uk/forum/index.php?showtopic=235735&p=2166614
You have an email back from PPP Hunor. ;) For some reason your replies had gone into our spam folder.
Hunor
I've got the mail, I like the offer, I sent a reply with some questions. Probably next month I'll order the chip, till then I need new and bigger injectors :D If the chip is for 250cc injectors can I put biger ones in like from a Golf mk4 1.8t, 317cc? You guys throw around with G60 injectors and GT parts like you could find them at any corner :P In my whole life I seen only one G60, and I can count all of them in Romania on one hand.
