Author Topic: Polo G40 hose  (Read 4260 times)
Offline Alexiskayak_7
Polo G40 hose
« on: April 04, 2008, 08:56:19 pm »
My G40 has still the stock hose, as i've seen the supercager (pressure) hoses are classical straight ring type, my only problem in the spiral hose between g lader and intercooler. Can i put a classical type again to, does it bends a little so it prevents the air flow? Or there is special hoses that i can use?
 There is  picture for the hose i mean
 [attachment=11]
Offline supercharged spaniel
  • GRRRRRRR
Re: Polo G40 hose
« Reply #1 on: April 05, 2008, 10:23:37 pm »
[quote pid=696 author=Alexiskayak_7 date=1207338979]My G40 has still the stock hose, as i've seen the supercager (pressure) hoses are classical straight ring type, my only problem in the spiral hose between g lader and intercooler. Can i put a classical type again to, does it bends a little so it prevents the air flow? Or there is special hoses that i can use?
 [attachment=11][/quote]
well its a little difficult to understand exactly what your asking but i'll try my best.  that picure is not a stock hose boost pipe.  yes you can re-fit the original one though its a little more flexible to allow movement of the engine but are prone to splitting.
« Last Edit: April 05, 2008, 10:24:01 pm by supercharged spaniel »
Re: Re: Polo G40 hose
« Reply #2 on: April 05, 2008, 10:52:47 pm »
I mean can i use a straight type hose, than a spiral one?
