Author Topic: Polo g40 to g60 oil feed and return  (Read 3976 times)
Offline John-125
« on: November 04, 2014, 09:01:51 pm »
Putting a g60 charger on my g40 can I have oil lines made up or do they have to be a certain length ?
Offline Jezza-7
Re: Polo g40 to g60 oil feed and return
« Reply #1 on: November 04, 2014, 10:23:51 pm »
I'd look into getting some made to fit, but they could cost a lot.
G40 standard one will more than likely be too sort. I know the G60 has a really long oil feed so you could just buy one of them as it should be plenty in length.
Have you looked into a standalone oil system?
« Reply #2 on: November 05, 2014, 09:36:01 am »
g40 and g60 feeds on their respective engines are the same part!
so maybe a stock feed will fit... then extend the drain with some hose.
Offline marky-x5
  • If in doubt flat out
« Reply #3 on: November 05, 2014, 12:45:07 pm »
I've just fit my G60 and as Pete said the oil feed is fine, for the drain I bought some hydraulic hose with the same internal diameter cut it to length and that seems to be working fine.
« Last Edit: November 05, 2014, 12:46:49 pm by marky-x5 »
Offline John-125
« Reply #4 on: November 05, 2014, 09:22:11 pm »
Thanks guys think I'm gunna have some made up as then my be able to hid the lines a bit more
« Reply #5 on: November 05, 2014, 09:27:34 pm »
i'd ensure they are exactly the same diameter, as they regulate oil flow.
