Author Topic: G40 eaton help please  (Read 3962 times)
Offline G40breadvan
« on: September 08, 2014, 07:18:11 pm »
Hi I have recently been dropping my g40 lump in a loon shell.
I have also fitted an eaton charger, FMIC, 250cc injectors, chip to suit.
I bought a manifold but it was a pile of s*** so haven't fitted.
It all runs and drives but at low revs when setting off the car tends to stall or loose revs so you have to give it some throttle.
I was just wondering if anybody has any ideas what may be wrong?
P.S the car ran perfectly in the last car with the old charger, I have used everything out of the old car in the new one.
Jack
Offline GR40
Re: G40 eaton help please
« Reply #1 on: September 08, 2014, 10:21:04 pm »
Check for leaks, obstructions or dirt in the air mass sensor and re-adjust your idle screw and throttle cable. Also check if your belt is too tight.
Offline G40breadvan
« Reply #2 on: September 08, 2014, 10:43:25 pm »
Thanks for the reply, I will have a check around.
How would I know if the belt was over tight?
Offline Ben.lopo
  • Cereal
« Reply #3 on: September 09, 2014, 02:27:02 am »
And distributer timing?
Offline markg40T
« Reply #4 on: September 09, 2014, 01:06:56 pm »
Check the CO pot aswell to make sure the resistance is correct.
i had this on my g turbo and it read 1100 ohms and chaged it to 600 and it ran fine.
Offline josé
« Reply #5 on: September 09, 2014, 07:41:41 pm »
I'd check your battery is good mine used to cut out and stall at low revs changed the battery and all was well
Offline vwmk3jon
« Reply #6 on: September 09, 2014, 08:52:03 pm »
Should be able to twist charger belt through 90° like a cambelt.
