Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Club G40 Forum
Technical
Engine and Transmission
1341cc Headgasket
« previous
next »
Pages: [
1
Go Down
Author
Topic: 1341cc Headgasket (Read 3140 times)
Robin
194bhp - 1341 Turbo
1341cc Headgasket
on:
December 23, 2008, 10:17:02 pm »
Chaps
I am guessing i need to use the Mk4 1.4 8v headgasket for the G, the question is has anyone knows if there is much difference between the ones from GSF/ECP and the VW ones apart from the price difference?
Administrators
The CV joint killer
Re: 1341cc Headgasket
Reply #1 on:
December 24, 2008, 09:11:58 am »
I'm using the mk4 HG on mine, just got it from G&S. I don't think you have to use that one on a 1341, as far as I'm aware you can use the normal g40 one too.
Phil
Reply #2 on:
December 26, 2008, 01:40:09 pm »
The thinner ones raise compression, not ideal on a 9:1 as it is! I've been using genuine VW for mine, Only £20 made by vitor reinz.
The Duck
Reply #3 on:
March 24, 2009, 10:31:14 pm »
I'm using a metal headgasket on my 1341 engine. No problems with high compression ratio and I am pulling a bit of power however cam overlap helps keep boost down to 13PSI.
I guess it may depend on your remap.
Duck.
lance
Reply #4 on:
March 25, 2009, 03:13:27 pm »
whats best to use with being 9:1 which is the thickest of them? ill be running alot of boost so wanna keep my comp ratio as low as poss!!!
Administrators
The CV joint killer
Reply #5 on:
March 25, 2009, 03:41:39 pm »
standard G40 one
lance
Reply #6 on:
March 25, 2009, 03:50:17 pm »
do you not need to run differnt one with being 2mm bigger bores?
Administrators
The CV joint killer
Reply #7 on:
March 25, 2009, 05:32:20 pm »
nope
Pages: [
1
Go Up
« previous
next »
Club G40 Forum
Technical
1341cc Headgasket
