Febi discs
Started by z3i, June 13, 2014, 01:16:37 PM
z3i
Got some 256 brakes and want some decent discs Pete can get me some mega cheap Febi ones, but I'm a bit worried about them warping
Has anyone used them before? Any reviews would be great
Taylor
Tav
I used OEM VW ones on my 256 conversion.  I've also used Brembo HC's on the Clio.  They were really cheap and take a monstering.
z3i
Quote from: Tav on June 13, 2014, 02:02:10 PM
I don't trust oem brakes, my stupid little up has warped it's brakes really badly! And I drive that like a grandad!
JoeH
mmm, I remember reading somewhere that drilled discs are more likely to warp...
Febi aren't cheap quality, even if there price is, most people think they are at least decent / ok.
I would just run the Febi's and see what happens, I reckon you might be surprised.
Tav
Looks like Brembo plain are about £30 and you can get the Max grooved ones for £70.
Quote from: z3i on June 13, 2014, 02:17:09 PM
Doubt it's warped them, probably transferred pad material onto the disc (do you sit with you foot on the brake in traffic?) there's various guides on how to remove it by stamping on the brakes from fairly big speeds.
Drilled discs are more likely to crack, it's rare you truly warp a disc.
I use Brembo grooved on the Polo, and Brembo plain on the Audi- both seem fine.
I use OEM brembo ones on my g40 with wilwood 4-pots.  They've lasted years of track days without warping. They're just the bog standard discs you get from GSF or ECP.
I don't believe in drilled or grooved discs :)
