crank pulley bolt
Started by RyanC, May 24, 2014, 08:57:41 PM
RyanC
bit of a silly question but am i okay in reusing the crank pulley bolt? as it isn't a stretch bolt is it?
i know the g60 engines had problems with snapping but this was because they are stretch bolts.
it only confuses me because if you buy one from bartek it says for g60 and g40 but im sure g40 don't use stretch bolt like g60 do, and am i right in saying the g40 us 6 point bolt and g60 use 12 point
samg40
I'd certainly change it if I removed it. Not worth the risk. Alex had a crank pulley fail which killed his entire engine a couple of years ago.
RyanC
Okay mate just need to find the right one then as the one most places sell are stretch bolt for g60 even tho they say g40 compatible with I'm sure they are not stretch bolt on g40s
samg40
Pm peteg40 on here he supplies them. I replaced the actual crank pulley too, he also does those.
RyanC
Crank bolt is vw only im afraid.
I do new crank pullies.
AdzCM
Yeah, you'll get your crank bolt from VW for like £6 I think. I know it's around that price.
Part number: N 902 928 02
Might aswell change the crank pulley too when you have the old one off. Pete can sort you ;)
RyanC
cheers guy will do that already have a new pulley now :)
samg40
Quote from: PeteG40 on May 25, 2014, 02:05:38 PM
Is it? I thought you got me mine. Did you pick it up for me or something?
Quote from: SamG40 on May 25, 2014, 08:02:05 PM
yep I did
