Battery tray rust
Started by 1982mk1, February 01, 2014, 02:35:32 PM
1982mk1
Hi guys, so as we all know by now, the battery trays just love to rust through in most polo's ;D
So im going to be cutting the rust out, cleaning the area back and re-welding it up. Then seal all the welds and repaint.
My question is, can it be done from inside the engine bay, or will I need to drop the dash down and get at it from the underside?
I really dont fancy taking the dash out, but dont want anything to catch, burn while Im welding it.
Most of you must be experts in this area as its so common  :D
Thanks for you help.
Dave
Dash out and carpet out to do a decent job really. Dash isn't too hard to get out.
1982mk1
Quote from: Andy on February 01, 2014, 02:51:33 PM
OK will get on with it then. Cheers
Etches
Haha getting a dash out isn't the easiest job, Ross(dub star ) took a while this morning getting one out the polo I'm breaking. Wondered why the mrs feet were getting wet. Turns out the battery tray was rotten to the size of half a Mars bar !! Mine needs doing so bad now !
I find getting it back in to be the main issue! Comes out okay once the steering wheel and clocks are out if memory serves - should be some pics of this in my build thread.
dubstar
Brilliant - I thought getting it out was I tw@ !
mk3 polo dash has to be just about the easiest dash to remove ever!  Really can't see how you'd struggle much with one.
I'd definitely take that and the front carpets out, the carpet and underlay stuff will catch fire really easily.
dubstar
In hindsight what happened was the tapered centre dowel had formed a bond with the donut grommet, so when everything was free it felt like it was still fixed in somehow.
Just took a bit of torch action 'n head scratching before I was satisfied that it just needs brute force to set it free!
Just foxed me for a bit.
grungeisdead
When in doubt, bust the hammer and grinder out =D
Much like whipping an engine out, there's always one last thing you forgot to undo!
