Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Calendar
Login
Register
Technical
Superchargers / G-Lader
Standalone oil supply users
« previous
next »
Pages:
1
2
3
Go Down
Author
Topic: Standalone oil supply users (Read 17258 times)
Re: Standalone oil supply users
Reply #30 on:
March 04, 2014, 06:58:55 pm »
Yeah a pressure gauge is a must.
Im about to buy something like this
http://www.ebay.co.uk/itm/400537229506?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Administrators
The CV joint killer
Reply #31 on:
March 05, 2014, 09:39:06 am »
yep that's pretty much exactly what I had. You have to run an oil line into the back of the dash, I had a stainless braided pipe so it wouldn't rub through on the bulkhead or anything.
z3i
Reply #32 on:
March 05, 2014, 10:04:30 am »
That would be rather messy if it rubbed through inside!
Administrators
The CV joint killer
Reply #33 on:
March 05, 2014, 10:06:52 am »
indeed. another argument for using a pressure switch and a buzzer instead.
timmyb
Reply #34 on:
May 18, 2015, 10:21:33 am »
How fast should the oil be coming out when disconnected?
Reply #35 on:
May 19, 2015, 06:53:22 pm »
depends what oil you use.
normally at a slowish pace as its only around 5-7psi. I would say from the oil i use, its a constant stream but when it gets hotter it does run a little better.
timmyb
Reply #36 on:
May 22, 2015, 02:39:37 pm »
Okay thank you my pump was broken got new one now see what happens thanks again
Pages:
1
2
3
Go Up
« previous
next »
Technical
