Standalone oil supply users
Started by Jezza-7, January 05, 2014, 01:36:40 PM
yep that's pretty much exactly what I had.  You have to run an oil line into the back of the dash, I had a stainless braided pipe so it wouldn't rub through on the bulkhead or anything.
z3i
That would be rather messy if it rubbed through inside!
indeed.  another argument for using a pressure switch and a buzzer instead.
timmyb
How fast should the oil be coming out when disconnected?
depends what oil you use.
normally at a slowish pace as its only around 5-7psi. I would say from the oil i use, its a constant stream but when it gets hotter it does run a little better.
timmyb
Okay thank you my pump was broken got new one now see what happens thanks again
