Author Topic: Trials and tribulations of a cheap G40  (Read 70988 times)
Offline physicsfool
Re: Trials and tribulations of a cheap G40
« Reply #105 on: November 05, 2014, 10:03:08 pm »
Port & polished cylinder head, Schrick 268 cam, custom PPP ecu chip
Pipex cone filter, S/S 4-2-1 manifold and Longlife S/S exhaust system
Vauxhall Calibra ATE front calipers with 256mm vented discs & yellow stuff pads
G-laderseite Poly ARB blocks and TCA bushes
GMax suspension
Polo GT rear axle with ARB
Sparco Sprint bucket seat and Sabelt 4-point harnesses
Polo GT clocks
Stripped-out interior
Ronal 14x6 multi-spoke wheels with road tyres
Offline z3i
« Reply #106 on: November 07, 2014, 07:37:24 am »
Awesome!!!! :D get that g40 engine in there!
Offline Jester
« Reply #107 on: November 07, 2014, 07:58:59 am »
Yea get that g40 in it!
mk2 shell + g40 = awesome
Offline physicsfool
« Reply #108 on: November 12, 2014, 02:40:52 pm »
My iphone is slowly failing and dying. So i apologise for the poor quality images
Any hoo got the bog brush and contact cleaner out
As well as cleaning all the bearing and thrust washer
And then bolted and torqued the lot up.
Tonights job is popping the 3 pistons in (one is without an oil ring as i managed to snap it popping it on) Got a 7-10 day wait for a set.
The mk2 is off for its re-test today as the headlights appear to have confused the MOT centre. Lets hope todays tester is a touch more competant
Offline physicsfool
« Reply #109 on: November 12, 2014, 02:44:50 pm »
And i reassembled the head with the new cam and dizzy. Gave it all a good clean first
Offline physicsfool
« Reply #110 on: November 13, 2014, 11:51:38 am »
Last night was spent putting 3 of the 4 pistons in the block. got a fair wait till the piston ring set turns up. but plenty of other jobs in the meantime
And this morning went for a spin in a freshly mot'd and taxed motor
Offline physicsfool
« Reply #111 on: December 11, 2014, 01:14:41 pm »
So i bet my mate i would have this finished and drive it into uni by the end of the year, i may be losing a fiver.
But i have put some hours in this week after the piston ring fiasco
Oil pump and chain, poured some oil in to prime it
Had all the gaskets bar this one, so being northern i wasnt going to spend money on buying the whole set, cheeky bit of gasket paper instead
Oil started coming out of the filter hole so a mini oil filter is on for the time being, thread doesn't feel quite right so will change when i pop the oil in
Mad painting skills, good job i put newspaper down, one messy pup
And a metal head-gasket and precision tightening later and i have a head attached
Hopefully i will get an hour or two in before the weekend and get the timing belt cover on and the engine timed up
Offline Jester
« Reply #112 on: December 31, 2014, 07:41:06 pm »
Anymore updates on this Martin??
Hows the mk2 shell looking now?
Offline physicsfool
« Reply #113 on: January 01, 2015, 11:58:42 am »
I dropped my phone on Christmas Day, replacement screen should be with me tomorrow.
But the engine is in,
  • exhaust is back together
  • gear linkage is all set up
  • charger is in place
  • driveshafts all torqued up
Need to decide on an intercooler design and radiator position as it doesn't quite fit
And pop the wiring back in, so hopefully not too far off.
Pictures to follow shortly
Offline physicsfool
« Reply #114 on: January 12, 2015, 01:06:35 pm »
So then i timed the motor up and popped the cam cover back on,
And slowly its starting to look like an engine again.
I stole various parts off the GT motor like the starter motor and its wiring harness as well as injector jackets
And a touch more..
And then the Christmas holiday arrived, which meant whole days on the car, missus had an assignment deadline which worked well for me
So here is the GT engine which sadly i ended up breaking.
But it will make way for the G so i believe its a worthy cause
Dragged it into the workshop to take the engine out, G watching from afar.....
After a morning of sweating and dealing with driveshaft bolts
Both engines out and so i set about breaking the GT for parts
......And then on christmas day i dropped my phone. which buggered it proper. Being the holidays i had to wait a week for the next screen... However i couldnt stop working so voila....Engine in car now
With most of the engine loom in.... I chopped the central bonnet catch support out to make way for the intercooler which fits rather well, but had to make slight adjustments to the radiator so that it now sits in fresh holes.
With the rad fitted
And the cowling, I chose to use this one as it still fits and should have better draw as well as shielding the radiator from the exhaust manifold
It all fits...just
Need to finish off the cooling system pipework, figure out where the last few clips on the engine loom go and mount the oil cooler as well as fitting the last part of the boost system...
« Last Edit: January 12, 2015, 01:11:11 pm by physicsfool »
Offline Jester
« Reply #115 on: January 12, 2015, 06:47:20 pm »
This is going to be so sweet once done Martin, good job.
What sort of power you aiming for from this.
Offline Freddy77
« Reply #116 on: January 12, 2015, 06:50:22 pm »
That intercooler setup looks very familiar......  Works spot on!
« Reply #117 on: January 12, 2015, 09:34:59 pm »
Is this a new loom? You need to push home all the rubber grommets, otherwise they're not sealed and moisture will get in.
Rest looks spot on though  ;D
Offline physicsfool
« Reply #118 on: January 12, 2015, 11:47:18 pm »
No idea Matt, will get it on the same rolling road I used just before I took it all apart.
Yes it's a Freddy special. Yeah decent route and no real cutting to the shell!
Yeah Pete, he appears to have put to large ends in. So they won't push in any more! Will have to wait and see.
« Reply #119 on: January 13, 2015, 07:38:22 am »
They compress down a fair bit. But I'd send it back if they really don't push home, it's not much use otherwise.
