Trials and tribulations of a cheap G40
Started by physicsfool, December 22, 2013, 03:36:29 PM
physicsfool
And finally the pistons arrived yesterday, and one went straight to the engineering workshop
So i am hoping to work on the engine a bit this weekend, but at the same time painting the new house. As per its all happened at once
Etches
What the garage like at the new house? Posted those injectors and relays this morning dude!
physicsfool
Quote from: Etches on October 03, 2014, 03:40:19 PM
Non-existent, going to have to persuade my mate he needs a polo in his garage!
z3i
Could just store it at mine.... For when I paint it?....
C0UP3
May I ask how much it cost you to get the loom remade?
physicsfool
Quote from: C0UP3 on October 05, 2014, 02:59:50 PM
£200 with up rated headlight module. Impressive work
Before you stick that loom in I'd push some of those wire seals fully home, doesn't look like they're all seated properly. Still, at £200 for a complete remade loom the guy can't be making much if doing it properly!
physicsfool
Quote from: Andy on October 05, 2014, 08:32:07 PM
Yeah I will make sure all are tight and seated well. I priced up the wire separately and that was pricey
physicsfool
Got the rebored block and polished crank back
And finally it begins
AdzCM
These pics are bringing back memories haha!
Made any progress yet?
physicsfool
Quote from: AdzCM on October 28, 2014, 09:44:41 PM
Crank, flywheel and clutch are currently being balanced. Lightened the flywheel by a kilo so thought it best. So hopefully getting cracked on with it this weekend!
physicsfool
So my day has started very positively (considering it began at 6 am) I have bought a mk2 polo with a GT engine
and although the body work is a tad shonky it goes like stink. Conversion was done by a chap in south wales i believe and its done to a very good standard.
I didnt take this one but this is what the bay looks like
So its in for MOT today as it needs one and then i will be taking it for a spin around the Yorkshire wolds/dales.
I got the crank back today from being balanced so i can start putting the G back together in earnest now
JoeH
Is that the new daily, or the shell for the G?
physicsfool
I think I may be inclined to keep it as is and keep looking for a shell for the G as I really like the way it drives!
Had an interesting evening fixing problems for the MOT, mostly electrical! Stuff like the rear number plate lights and washer bottle motor. Wired up really interestingly but not in the most productive way. And put a more handbrake lever on as the old one was bent out of place!
The most difficult problem has been sorting the dipped beam setting as at the moment I only have sides and full beam. Figured it out to be the indicator stalk which isn't switching the power to the cable that supplies the light switch so no dipped beam.
I reckon I will drive it as is for the foreseeable future, but first it needs an MOT
JoeH
Any idea on the spec of the GT engine?
to be fair a highly modded GT engine in a lighter mk2 shell, probably isn't far away from a stock G...
Good luck with MOT
