Author Topic: Trials and tribulations of a cheap G40  (Read 70957 times)
Offline physicsfool
Re: Trials and tribulations of a cheap G40
« Reply #90 on: October 03, 2014, 11:42:34 am »
And finally the pistons arrived yesterday, and one went straight to the engineering workshop
So i am hoping to work on the engine a bit this weekend, but at the same time painting the new house. As per its all happened at once
Offline Etches
  • Still got the G...
« Reply #91 on: October 03, 2014, 03:40:19 pm »
What the garage like at the new house? Posted those injectors and relays this morning dude!
Offline physicsfool
« Reply #92 on: October 03, 2014, 06:53:07 pm »
Non-existent, going to have to persuade my mate he needs a polo in his garage!
Offline z3i
« Reply #93 on: October 03, 2014, 07:54:15 pm »
Could just store it at mine.... For when I paint it?....
Offline C0UP3
« Reply #94 on: October 05, 2014, 02:59:50 pm »
May I ask how much it cost you to get the loom remade?
Offline physicsfool
« Reply #95 on: October 05, 2014, 06:54:46 pm »
£200 with up rated headlight module. Impressive work
« Reply #96 on: October 05, 2014, 08:32:07 pm »
Before you stick that loom in I'd push some of those wire seals fully home, doesn't look like they're all seated properly. Still, at £200 for a complete remade loom the guy can't be making much if doing it properly!
Offline physicsfool
« Reply #97 on: October 05, 2014, 08:41:38 pm »
Yeah I will make sure all are tight and seated well. I priced up the wire separately and that was pricey
Offline physicsfool
« Reply #98 on: October 08, 2014, 11:05:46 pm »
Got the rebored block and polished crank back
And finally it begins
Offline AdzCM
« Reply #99 on: October 28, 2014, 09:44:41 pm »
These pics are bringing back memories haha!
Made any progress yet?
Offline physicsfool
« Reply #100 on: October 29, 2014, 01:02:11 pm »
Crank, flywheel and clutch are currently being balanced. Lightened the flywheel by a kilo so thought it best. So hopefully getting cracked on with it this weekend!
Offline physicsfool
« Reply #101 on: November 05, 2014, 01:27:03 pm »
So my day has started very positively (considering it began at 6 am) I have bought a mk2 polo with a GT engine
and although the body work is a tad shonky it goes like stink. Conversion was done by a chap in south wales i believe and its done to a very good standard.
I didnt take this one but this is what the bay looks like
So its in for MOT today as it needs one and then i will be taking it for a spin around the Yorkshire wolds/dales.
I got the crank back today from being balanced so i can start putting the G back together in earnest now
Offline JoeH
« Reply #102 on: November 05, 2014, 03:38:31 pm »
Is that the new daily, or the shell for the G?
Offline physicsfool
« Reply #103 on: November 05, 2014, 09:02:06 pm »
I think I may be inclined to keep it as is and keep looking for a shell for the G as I really like the way it drives!
Had an interesting evening fixing problems for the MOT, mostly electrical! Stuff like the rear number plate lights and washer bottle motor. Wired up really interestingly but not in the most productive way. And put a more handbrake lever on as the old one was bent out of place!
The most difficult problem has been sorting the dipped beam setting as at the moment I only have sides and full beam. Figured it out to be the indicator stalk which isn't switching the power to the cable that supplies the light switch so no dipped beam.
I reckon I will drive it as is for the foreseeable future, but first it needs an MOT
Offline JoeH
« Reply #104 on: November 05, 2014, 09:48:51 pm »
Any idea on the spec of the GT engine?
to be fair a highly modded GT engine in a lighter mk2 shell, probably isn't far away from a stock G...
Good luck with MOT
