She seems alot slower now?
Started by z3i, September 28, 2013, 08:01:20 PM
z3i
Evening all, well the G is finally back on the road :D (will update build thread soon)
but she seems to have lost alot of ponies
since it was last on the road ive changed exhaust for a complete ppp mani and system, gt inlet and the boost return mod.
ive finally fitted a stackk boost gauge (never had one before) but does 8 psi sound about right for my mods?
r1 jabba ported charger
BRV mod
gt inlet
1341 (accralite pistons)
ppp mani and system
51mm throttle
derestricted airbox
lightly ported head
psd high lift cam
what figure are other people getting? 8 psi doesnt sound like much, and there definitly isnt any leaks going on as most hoses where replaced and i double checked them all
the thing i did notice is i dont get that woosh sound from the boost return valve when throttling off after full throttle, to me that sounds like the return valve isnt closing properly, but it is, as i checked, full throttle closes the valve
is that also normal?
it does fell alot slower, much much slower, considering if anything it should be faster?
not really sure what to do, the charger was rebuilt 5k ago too, so its not that
thanks Taylor
JoeH
I'm not expert at all but:
- is it running on all cylinders? - all sparking?
- is it getting fresh correct amount of fuel supply?
- Is engine timing correct - with that cam?
z3i
Quote from: JoeH on September 28, 2013, 08:34:34 PM
yes too all of those, runs sweet as a nut, probably better now it has the gt mani on it
has a psd chip for 1341cc so the fueling will be near enough there, no pinking
the power off boost is lovely, only when i put my foot down, it used to struggle to grip in second in the dry, now its soo much slower :/
does 8 psi sound about right?
Andy
Boost sounds low.
Is the cam timed up correctly? Any rags left in boost pipes? Sure there's no boost leaks? Are you getting full throttle and BRV fully closing from the throttle cable?
10 psi is what i run from about 3k upwards and i got a similar spec. 12 psi is what i get around 7200rpm.
Did you blank off all correct pipes from return mod?
Also is your stack gauge mechanical?
z3i
Dont have a vernier pulley and mechanical timing is good as i checked it 5 times when changing
cambelt
that could be an easy mistake lol, but defo no rags haha
yeah thats what i checked andy, turned the car off and put my foot flat and the brv completely closed... well it did visually....
im gonna double check all my pipes tommorow then, is the best way to check for boost leaks to have the car run at idle, disconnect the brv and close it to hear for any hissing? this wont damage anything will it?
just to confirm i should be getting that woosh noise when revving the car at a standstill? i.e full throttle for a split second then off? dont want to sound like a chav or anything, just as far as im aware it should, and from it not doing it points to the throttle. (not that ive played with it since having the car off the road
yep mechanical, brand new so should give a good reading?
thanks for clarifying jezza, its definitely boost and something ive touched then lol
i blocked off the pipe the goes into the big pipe to the isv? and obviously a blanking plate with hylomar. think that was all
fuel pressure reg to main vacuum pipe
it was around 8 psi at over 7k so pretty poor in comparison to yours
ill go over things with a fine tooth comb tomorrow then
if i disconnect the brv and close it at idle i can see if it leaks air through?
cheers guys, if you think of anything else lemme know
thanks
Andy
Does the throttle body open fully when the accel pedal is flat to the floor? If the TB's a new one to your build it's possible the BRV is sealing, but that you're not getting full throttle.
z3i
Ah see what your saying, Didnt think to check that, cheers mate.
Double checked boost and it's 6psi, no wonder it's slow lol
When I put my foot  down in third at low rpm (not much engine noise) there is a hissing noise, like boost forcing it's way through a gap, but I could be imaging that
need to check my shit
Is the way I described above ok to check boost? Not gonna run mega lean and damage something
With the engine off can you hear it making the wot switch?
z3i
Also didn't think to do that, thanks mate,
All i've done la remove and refit the throttle twice, is the same one I used  before
I'm beginning to worry it's my charger lol
Any oil in the boost pipes?
Could always take the t-piece off the top of the throttle body and see if its closing.
Ah i just red something, you out a gt inlet on? Was that something you have put on as a newer item? I had a problem where the throttle cable kept slipping out and wan't sitting correctly and it was like the car had no oomph. It tore the rubber bung and i sorted this but sticking about 10 washers under the throttle bracket and put a new bolt in. The gt inlet sits slightly lower so might be worth checking.
z3i
James you legend!! Cheers mate. I thought the cable looked a funny angle, and that would explain why the bar at the back doesn't fit and the pipe for the ischemia is quite stretched. I've adjusted it for now but I need a spacer for the bracket. Instead using ten thousand washers :P
r is mental fast now!!!
Thanks people :D
JoeH
Would this be a likely issue with anyone fitting a GT manifold do you think?
I would say so.
They sit lower but only by say 10mm.
If you need a metal clip for the cable let me know as i may have a spare one.
weird, never had this issue... btu there are two different gt inlet part numbers i think.? or i might've made that up!
