Author Topic: She seems alot slower now?  (Read 9916 times)
Offline Jezza-7
Re: She seems alot slower now?
« Reply #15 on: September 29, 2013, 07:59:21 pm »
This caused me massive problems a few years ago. Had to keep pulling over every 5 mins at one point until the mighty tie wraps came out.
Offline z3i
« Reply #16 on: September 29, 2013, 08:31:31 pm »
Fuck it!!!!! I'm broken down outside of Marvell zoo supposedly picking my gf up from a wedding
Lost all power, lights went dim, water and fuel gauges stopped reading the it conked out, won't start, so bumped it, same again, everything, turned main beam on and it cut out. Alternator light didn't come on through any of this.
Now I'm stuck between a main road and a hill in the pitch tucking black in a forest.
The joys of owning a G
do you think the batteries judged and not taking any charge?
Offline z3i
« Reply #17 on: September 29, 2013, 08:35:50 pm »
Batterys a year old
Offline z3i
« Reply #18 on: September 29, 2013, 08:39:52 pm »
New alternator
Offline z3i
« Reply #19 on: September 29, 2013, 08:42:52 pm »
On the bright side I did just wax it so atleast Italking clean in the. Dark
« Reply #20 on: September 29, 2013, 09:12:34 pm »
hall sender? coil/
Offline z3i
« Reply #21 on: September 29, 2013, 10:07:47 pm »
Got home, Dad had to come out and jump the battery
The alternator isn't charging the battery but the batteryvlight isn't on, like to say the alternator isn't charging it
 I had to charge it of dads car drive as far as I could with no lights, eventually go flat, Dad charge it again, keep doing that until I got home.
Any ideas I'm raping the wiring diagrams on Haynes
Ive just washed it but water didn't really get anywhere near electronics
Offline Andy
« Reply #22 on: September 30, 2013, 06:52:53 am »
Is the thin blue wire still attached to the alternator?
Offline z3i
« Reply #23 on: September 30, 2013, 11:34:27 am »
Yeah I checked that after consulting wiring diagrams. How can I check continuity through the wire,  don't have a multi meter long enough to reach the clocks and the alternator
Offline Jezza-7
« Reply #24 on: September 30, 2013, 11:59:08 am »
Use a long piece of wire to make it long enough.
Offline z3i
« Reply #25 on: September 30, 2013, 01:18:46 pm »
Lol, sorry for retarded questions :P if I run a wire like you say and it works, means I have a brake in the wire, if it doesn't then it could be faulty alternator.
Is the wire pretty straight forward to get at behind the clocks?
thanks guys
Offline z3i
« Reply #26 on: September 30, 2013, 02:08:29 pm »
Whats the wire actually for? Could I just earth it to see if it solves the problem?
Offline z3i
« Reply #27 on: September 30, 2013, 07:50:08 pm »
Ok it's not the alternator, plugged a working one in, same problem, checked continuity on the blue wire back to the bulk head, is fine. Can't see where it goes inside the car, it's a fucking mess! I don'. Understand what it's for?
Offline z3i
« Reply #28 on: October 03, 2013, 10:07:36 pm »
Found the problem, my 5 month old refurbished alternator I bought of here was fudged
