Lysholm supercharcher
Started by samuel.cole, September 03, 2013, 02:18:49 PM
Etches
Have a read around the forum dude, you will need to check your ecu chip injectors etc. make sure all the bits arnt specific to the charger. That includes the cam too
z3i
Wow thats expensive! Yes it would be bolt on once youve removed all the bracketry from yours. Though its not really fair as like jezza said the lysholm charger is worth  £2000 whereas my glader is worth £400 (ported and rebuilt)
z3i
Cheers tom, just been thinking about this. Ive got a custom map and an ecu with a lower map sensor and a glader specific cam. But as long as i can get it running and get a cam at a later date. I was planning on getting a remap at a later date so yoof could then put then uprated map sensor in and map it then
Like the Eatons, the only real way to quieten one of these down is to have them sucking through the throttle body instead of blowing through it. At least that way when the throttle's closed you're damping some of the intake noise.
You could always try adding a throttle body on the inlet of the charger as well as retaining the standard one. I'd imagine getting the cable working properly might be a bit of a pig though. Or maybe you could actuate it with a vacuum/boost controlled device.
z3i
Quote from: Andy on September 04, 2013, 07:59:03 AM
Is that what the cooper s has on it?
Maybe worth looking at one to get some ideas? Cooper s as standard are quite quiet. The superchcharger isnt very loud at all, compared to how they sound on g40 conversions
Bmw must have got it spot on
samuel.cole
well tbh if i dont wantmy setup its worthless to me, if you swing a bit of cash my way i would be very happy to swap!
lysholm are too loud for my liking, sounds cool but i couldnt drive it every day, maybe as a track car which was its owners purpose was.
Here is a G40 with an air raid siren:
http://www.youtube.com/watch?v=epw1EZatQ2Q
Beleive this to be phil j's old car.
And this with an air box (not quieter at all)
http://www.youtube.com/watch?v=JBUN3c8D3Ss
And this is a good one for the sound whilst driving in a built up area, G60 rado though.
http://www.youtube.com/watch?v=dxhDLMrlL4Q
The bracket that is on the car is also custom made.
Sam, you would need a new set of pulleys, charger bracket, charger, outlet elbow, pipe work and then air filter pipe work.
Oh and blanking plate or boost return pipework. I think the injectors are G60? Check if they are green.
Keep the standalone oil system you have though, thats worth keeping.
If you want a set of standard pulleys i got them you can have as they are of no use to me, but if you want PSD toothed ones expect to pay around £200 mark, although some recently went for a lot less.
Charger will cost anywhere between £250-£500 ported or standard. Outlet elbow a few £ and pipe work slightly more cause you got a front mount.
You can sell the charger setup for over £1000, or swap it for someone with what you need plus cash your way. Or sell it and get a G45 charger.
Quote from: z3i on September 04, 2013, 06:22:03 AM
They used to sell new nearer to the £2800 mark i think.
z3i
£2800!! Dayum!!
Thats too much for me, youll get a better deal selling it on here as a kit then buying a charger and the other stuff. Might take a bit longer to sell but in the long run
if i had a bit of cash id swap you all my g40 bits and monies
z3i
Also i think it sounds friggin awesome!! Lol
Yeah but they wont go much for more than 1k these days. Plus that was a new price.
if the throttle had been placed before the charger, it would have reduced the noise, heat and parasitic load on the engine on all but full-throttle.
Thats why dragster chargers are fairly quiet.
Speak to Jonny Betz and BBM to find out more. There a bit reluctant to give out some info though as i once found out.
samuel.cole
hasnt got anything on the end of the camshaft, i assume its standard!
Sam said it was completely standard.
samuel.cole
