Author Topic: 13" alloys over 256 brakes  (Read 9200 times)
Offline Phil
Re: 13" alloys over 256 brakes
« Reply #15 on: August 07, 2013, 06:17:44 pm »
Well I sold my tramonts to a kiddy with a 6n 16v, stock 256mm brakes. He wanted to come try them, I told him they probably wouldn't fit. When he turned up, they did. Can't remember offset or width, but I had them to go on an early polo.
The delta mics I'm selling have the bolts backwards and the allen head recessed for maximum clearance, would be surprised if they didn't clear a set also.
Offline Jimmy B
« Reply #16 on: September 13, 2013, 06:58:50 am »
Did I hear somewhere that the berg cup guys in Germany were using large go-kark brakes to get the 13's to fit over?
Offline dekerf1996
« Reply #17 on: September 17, 2013, 07:58:54 am »
Wouldn't surprise me. Been speaking to a local Motorsport place and they were saying they were running 300mm brakes (I think, certainly bigger than 280s) under 13inch comps, and I was just checking for clearance on my 256 brakes!!!
It does take custom barrels on the comps but they are no more expensive than standard ones and come with slip rings incase you are running over 500bhp
Offline Jimmy B
« Reply #18 on: September 17, 2013, 08:41:22 am »
Nice!
Offline Kustom
« Reply #19 on: September 17, 2013, 02:56:56 pm »
Assuming you were going to use a motorsport wheel (eg compomoive CXR) then are there calipers available which would fit under them? Ive heard hi-spec do/did some but I want avoid them. Wilwood seem to be good and cheap but the calipers are quite big. Does someone like AP or Brembo do a caliper?
« Reply #20 on: September 17, 2013, 03:35:19 pm »
Midilite fits under with a stock offset Brembo 256mm Golf 16v Disc, 13" CXR ET0 (or less)
Need big arches to run them though  ;)
Offline Kustom
« Reply #21 on: September 17, 2013, 04:08:27 pm »
you'd make a good salesman yoof lol. I thought I read somewhere you were running like a 2mm spacer aswell as ET0 wheels?
Do you run that size on the track aswell? and what are you running at the rear?
« Reply #22 on: September 17, 2013, 04:30:04 pm »
I do that's true, one of my wheels catches at ET0 because of balance weights. So run a 2mm spacer for clearance.
If I was getting a custom set made I'd go ET-5 so I've got room to spare. My other set of CXR are positive offsets, so I run a 20mm spacer all round, along with 10mm stub axle spacers at the back.
Managed to sell you plenty of shit over the years, and you work in F1. Must be doing something right  ;D
