Wits end
Started by physicsfool, August 04, 2013, 09:00:20 PM
physicsfool
Evening all,
So after months of rebuilding, i have come to the fateful restart.
And........ strong spark. fuel is good. but. no. life.
Should I compression test and sort ignition timing out first?
ANY advice however wild will be considered. I am contemplating dropping it off at the local garage. desperate times
z3i
Ah man! Sorry to hear after all the work :(
timing definitly right? Is there absoloutly nothing at all? Not even a little bit of life?
like you say. Id double double check timing
i suppose with the compression, if it was that low the engine would turn over much easier and you could hear it
GR40
Timing is crucial, no timing means u may be igniting the cylinders way late and not making enough pressure in them to sustain the rotation of the crank!
samg40
Double check the HT leads order. Its caught a few of us out before!
physicsfool
Update. I mentioned my rotor arm was facing 3pm. So I swapped the 1 ht lead to 3pm from 9pm.
And there are signs of life. Engine is just about catching. But requires me to have my foot on the accelerator pedal the whole time.
The cam shaft isn't rotating smoothly, v jerky. I tightened the end bolt to 65nm as per Haynes.
Any ideas folks?
Swap the other 2 leads. 1342 from 9 oclock anti clockwise
physicsfool
Yeah I swapped all 4. So 3 is at 12, 4@ 9pm and 2 @ 6 pm
physicsfool
Oh wow. I had 4 and 3 the wrong way around. What a twat I am.
Long story short she is runnnnning. £500 and 2 months later.
Now just waiting on the oil feed banjo and I can take her for a drive
z3i
gaz g40
Glad youve sorted it mate!!
Etches
Quote from: SamG40 on August 05, 2013, 12:30:09 PM
Great shout Sam! We've all done it before haha
its complicated by the fact someone put the little pulley thing on his dizzy on 180 degrees off!
and banjo be in the post tomorrow mate!
NeilG40
I never understood why there wasn't a diagram of the dizzy in the haynes manual with the numbers on it, I ended up drawing on in there myself after getting the leads the wrong way round.
samg40
Quote from: etches69 on August 05, 2013, 05:39:22 PM
Ask Robin about the fun we had with his HT leads last year at Blyton. We (he) still got it wrong about 5/6 times even with a working car to copy from!
z3i
Quote from: SamG40 on August 06, 2013, 11:10:05 AM
haha! bad times!
ive got the magnecore ones and they come labelled :)
then just used a sharpie and wrote the numbers on the dizzy cap
