wide range lambda probe or stock
Started by Hunor, May 15, 2015, 02:02:35 PM
Hunor
Wide range lambda probe for a turbo G40 or the stock?
Alexiskayak_7
What do you mean?
To plug a wideband o2 sensor to the g40 digi ecu? It won't work...
Buy a new stock one...
Meaculpa
Quote from: Alexiskayak_7 on May 16, 2015, 07:14:12 AM
What do you mean?
But if whe plug the narrow end to the ecu it candidature work ?
Bosch lsu 4.2 have 2 ending, one for wideband gauge ansd one to ecu.
I think the usual thing to do is to leave the standard narrowband lambda connected to the ECU and fit a 2nd wideband probe into the exhaust if you want a wideband gauge.
The narrowband output some wideband gauges have isn't supposed to be quite the same as the standard narrowband probe.
