Ppp group buy
Started by gaz g40, May 28, 2013, 02:54:24 PM
gaz g40
Ive messaged yoof with no reply was just wundering if anyone wants in on a group buy for ppp manifolds and/or exhaust systems aswell
Ill kick it of
Gaz g40- 4branch and system
If in wrong place can mods please move as i cant post in group buy section cheers
DaBigGinger
dabigginger - system depending on price and availability date
Tav
Tav - I could maybe stretch to a 4 branch and system...
Alex
Alex - 4 branch would be good
gaz g40
Tiday wel minimum numbers for four branchs was 3 people so il get in touch with yoof an see what prices are with three people wantin manifold an system
Craig g
Craig g - id take a 4 branch depending on price
gaz g40
Well its like anything else the more that wants them the cheaper theyll be
C0UP3
Quote from: Craig g on May 30, 2013, 09:44:05 AM
C0up3 - may be interested in both but mainly on the system (price depending)
z3i
Is this actually happening? have you contacted yoof
need a full system inc mani, single exit
how much are we looking at for the group buy?
thanks, taylor
if this doesnt work out, im just gonna go to longlife and get one made
gaz g40
Ye iv contacted yoof! Hes going to sort prices out for us. The more thats in the cheaper it will be. Il pm him again to remind him we want prices cheers
z3i
Thanks mate, before i shell out can anyone tell me what the fitments like?
Im worried it will stick down a bit and hit all the speed bumps
the one i have on now touches the gearstick box, havnt seen any pics of it on a car, and would like to see before a shell out £600 odd
Going out on a limb, it's the best fitment for an off the shelf system you can get, unless Haysey has fitted it, and then it's about the worse thing.
63mm is a fair old size of pipe to fit down a Polo tunnel, and the weight of stainless systems will stress rubbers more. The system/manifold has one sleeve joint at the manifold/system and one flange joint post mid section, so there's a small degree of freedom the exhaust can be tweaked.
We farted around with the manifolds for a long time, various different designs for clearance with different toothed belt kits, and the charger position with No.1 exhaust runner, ended up with something that's the most clearance possible, without impeding flow.
This was the first design:
Second design with greater clearance to Cyl 1 runner:
These are a single piece and both the exhaust and manifold have lambda bosses.
z3i
They look gorgeous! Thanks for posting that, id personally prefer the second design to give more charger clearance
yeah thats what i found with mine 2.5" doesnt fit too well in the tunnel. You got any pictures of the amount of ground clearance as thats my biggest concern
thanks mate
QuoteGoing out on a limb, it's the best fitment for an off the shelf system you can get, unless Haysey has fitted it, and then it's about the worse thing.
screw you bloaty-head!  Mine fits very nicely I'll have you know.
samg40
What do you recommend in the way of rubbers Yoof (ooh er) for the PPP system? I'm assuming you arent using the stock hangers anymore?
