Engine building
Started by AlexG40, June 23, 2012, 07:39:41 PM
AlexG40
I'm going to be building up my engine from scratch pretty soon. I'll be using the Haynes as a guide (it's not let me down before) but I wondered if anyone has any hints and tips before I start. I've got the tools and plenty of clean workspace but anything else I should be looking at?  I'll probably document the build as I do it and it may make a decent FAQ article when it's done. (It will also mean if I miss anything one of you might spot it!)
Alex
List of some helpful tools/bits:
Clean Rags
Fresh engine oil in a small squirter
Plastigauge
Feeler gauges
DTI & base
Good block scraper
Pipe cleaners/brushes to remove debris
Torque Wrench
Paint pens/ stamps for marking bolts when tight
Gasket sealant
Long splined head bolt tool
Just have a good read of Haynes and set aside a few hours, building them isn't hard just be methodical, and don't force anything, if it feels wrong, it generally is.
randombadger69
Use sealant on your sump gasket. I didn't and its leaking! Grr >:(
AlexG40
Cheers for that. Got all that covered except the DTI.
Hit my first snag today. There's something stopping the rods on 3 of the piston assembly's from having full movement. I'm not 100% sure why as theyve been used together before with no issue that I knew of although the engine wasn't actually run.
Looking at the pistons it appears there's a small lug that seems to be fouling the top of the rods.
Have I missed something or is this a minor fault with the pistons that I need to address?
Finger belt sander is your friend, make sure everything's clean afterwards.
They all stamped with 'EX' ?
Robin
Its worth running a tap down the head bolt threads on the block as well Alex to make sure there is no crap down there and the thread are all nice.
AlexG40
Quote from: Yoof on June 24, 2012, 08:55:13 PM
I'm back in the house now, but as far as I can remember they are.
Fred
Head bolt thread.
Am i correct by saying Metric Fine 10 x 1mm pitch ?
Fred.
AlexG40
^ Sounds right. I'll check when I get to the garage.
jez1272gt
be carefull when using a tap to clean the thread, should really use a thread chaser but it will be ok if your gentle/careful. Make sure you get all the crap out of the bottom after too  ;)!
