G40 boost preasure
Started by Oli b, August 05, 2011, 06:18:26 PM
budunt121
i get 9/10 psi with a standard charger that needs a rebuild and running a 65mm pulley with jabba chip and g60 style belts and the gt inlet
poloandyb
i get the same 0.9-1bar near red line with a 65mm pulley,r1 charger,standard v belts with beltslip spray on them
budunt121
i would have thought you would get more with the r1 charger , i dont know if i should rebuild mine or go for the r1!
poloandyb
their all about same to be honest from what i can tell,my mates got a full blend and he's running about the same.
AlexG40
Don't forget that if you've got ported bits your boost may drop relative to others.
theres a big difference from 9psi to 0.9 bar - 1 bar is 16psi.
You see about 0.2 bar difference with a ported charger
dub-disaster
I thought one bar was 14.7 psi  ?
cheys03
Justin14100
Normally 1 bar is seen as the pressure of the earths atmosphere at sea level, which is 14.7 psi, but 1 bar actually equates to 14.5psi.
Andy
Justin - you're confusing bar with atmospheres. Bar is an SI unit, so its definition doesn't change, atmospheric pressure at sea level is about 1013mBar.
Justin14100
Yes, and 1atm is 14.7psi - which is why people think 1 bar is 14.7psi - because 1bar usually is just accepted as the pressure of the atmosphere. hence the misconception.
my bad - 14. whatever.
even so... 9 psi wth a 65 is low
scotsjohn
Would 1225 Torr sound better? lol.
budunt121
i thought it was i may just rebuild this standard one unless i find a cheap r1/full blend
