Breaking 62k G40 Breadvan, lots of performance bits inside, most brand new
Started by grungeisdead, September 05, 2011, 02:04:19 AM
is the charger the one we had apart to service, if so then its an R1, not stage 4
grungeisdead
It is mman, ill let Luke know bbut he was just after any working charger as his shit some oil seals so im sure he wont mind. Nice one for the heads up.
Need to come see you soon and get you motivated to crack on the mk2!!
Not wanting to fall out with you mate or cast aspersions but just wanted to say I think its a little bit naughty advertising it as -
'Rebuilt Supercharger - Ported to stage 4, fitted with new oil seals, bearings and kluber grease, apex seals were not replaced as were within the limits, rebuild done a few months ago, unused since - £350'
When it has had only the centre scroll bearing replaced (the other 4 were untouched and condition unknown) and 5 oil seals.  We put some cheaper nitrile seals in that i've never used as you agreed to test them to see if they were up to the job or would sh1t themselves as soon as used.
In addition it also had some damage to the outer side charger casing.
The world of G40s is very small and the same amount people buy / sell to each other - so in order to avoid any future problems please could everyone be as accurate as possible in describing their goods otherwise it can lead to problems with us admins sorting out disputes!
grungeisdead
I thought we did all the bearings, but my minds fried being a stoner. Ill speak with Luke today, as ive not posted it yet, and see what he says and offer a full refund if he wants one!
ereeiz
The mk1 golf oil cooler- does it just need a sandwich plate to work and nothing else? i got one of them lay about somewhere :D
I'll have it if that's all it needs! How much inc. postage?
grungeisdead
All you need for oil cooling is a cooler, lines n a sammich plate, either thermostatic or non. The former being the better choice. Postage is 8 quid via courier, so whatever its up at plus that:-)
ereeiz
£28 for an oil cooler kit sounds like a bargain. What's your paypal address?
Can they just leave it there if no one's home? I'm at work all day every day pretty much. I'm not in any rush for it either if that makes any difference.
Just to clarify all I'll need is a sandwich plate to make the kit work, yeah?
grungeisdead
Yeah the sammich plate will need appropriate bsp fittings to match the lines but thats it.
I am assuming your sammich plate has.the adaptor to extend the thread for the oil filter. And the seal is in good condition.
However the adaptor and seal are only a few quid
Poopal is yousafn@gmail.com
Unlikely they will leave it. Outside, normally signed for, but they will leave a card. And you can rearrange with the depot or inform them to leave outside at your liability :-)
grungeisdead
Following bits.now sold
Front omp braces ( both upper)
Rear upper omp.bracebrace
Charger
G loom
G ecu
G fpr n fuel rail
mk2 ignition amp,loom and dizzy
Ta
luke s
Quote from: PeteG40 on September 07, 2011, 07:59:31 AM
Pete saf has explained all this to me but i just want a working charger to get me by for the rest of the show season then over winter ill rebuild mine but cheers for your imput
Luke
ereeiz
I'll pass on the cooler kit for now :( gotta move out in 2 weeks and found out how expensive it is to get a flat today :o lol
If you still got it in a few weeks I'll have it. Sorry to mess you about!
