Which gasket/seal is which
Started by Oily Fingers, January 29, 2011, 03:49:14 PM
Oily Fingers
Right now got to the point that i can start to build up part of my eaton engine.
But as i am doing from complete scratch (i started off buy buiing a bare block)  so i got no reference really and the haynes manual is shite as usual.
going to be ordering these from Bartek
http://www.bar-tek-tuning.com/cgi-bin/cosmoshop/lshop.cgi?action=showdetail&wkid=5893&ls=en&nc=1296313499-6284&rubnum=&artnum=2140046&file=74&gesamt_zeilen=0Tsuche--g40
obviously i know the sump gasket and the black seal on the left and the two cranckshaft oil seals, just want to know the other seals in the top right on the picture and the silver ones behind the black one.
Alexiskayak_7
The o-rings (from the biggest to smaller):
1)Water pump seal
2)#15A (from etka) If i remember, G40s do not need that seal, just use silicon.
3)The water tube behind the water pump that connects wp and thermostat housing
The 2 silver and the black one are the same seal #8 (from etka).
All the 1272cc engines have the same block seal kits. You'll find out that you will need 1 of the 3 seals.
Why don't you just buy the gasket & seal kit from GSF? Will prob be about £20
Alexiskayak_7
Yeah, Hayesey is right, bartek is way too expensive....
I bought a goetze block seal kit for 48euros...
Oily Fingers
kool many thanks for pointing out whats what.
i did mean to say i MIGHT be ordering these.  i havent checked with gsf yet as i havent had a chance to get up to them and speak to them.  I should have the afternoon free next saturday so i'll go then.
