Which Lambda probe?
Started by Justin14100, September 25, 2009, 01:57:55 AM
Justin14100
OK, so finally found my running problems, unplugged the lambda and its running MUCH better!
Looking on ETKA, there are 2 lambda sensors.
030 906 265J - PY, AAU, 3F, NZ
and
030 906 265N - PY for models without catalyst... ]
I have a decat pipe so would it be better to get the second one? Will it even make a difference?
Thanks!
the second is one for the euro ECUs which were preprogrammed to run without a cat (as laws over there didn't need one).
Use a standard catted one.
Andy
The only difference will be cable length - the actual sensor should be the same.
thats what i thought after i posted.  Most lambdas are very similar anyway, just the plug on the end.
