Excessive oil out of boost return in throttle body?
Started by ben_91, August 08, 2009, 12:40:34 AM
ben_91
Just brought my first G40, after driving back i opened the engine bay to find a lot of oil.
Why is this? The car is missing the recirculation pipe which takes it back to the supercharger.
The car has a chip, g60 injectors, gt inlet manifold, decat ect.
Does the charger need oil in the intake to lubricate it or is it just a straight oil feed in and outlet into the sump?
Ben
ben_91
so if that's the case does it mean there is a bust seal somewhere because there is a lot of oil coming out of there?
scotsjohn
Sounds like it. Any idea when the charger was last serviced? Jabba issue a dated service doc.
ben_91
about 8000 miles ago.
Will this be covered?
Ben
SuperMario
sounds like its oil seals in the charger, when mine whent it started with a little oil coming though, then just shed loads. 8000 miles it should be fine, get in touch with who ever serviced it
scotsjohn
Hate to sound like the Angel of Doom, but if it was Jabba then their warranty is time limited at three months (six months if they fit it). Don't know what they think about the removal of the re-circulating system, but it's something they'd probably point the finger at. I'd keep that quiet.
ben_91
ah, ok. is there anywhere that i can by the seals from without having them fitted. whats the most likely seal to have gone? could any bearings have failed in the process?
also are there any rebuild guides anywheres
g-laderseite.de sells seals... but you really need it apart to see what's gone.
