Need to know asap rocker cover gasket???
Started by Kayag40, June 17, 2013, 02:38:36 PM
Kayag40
Guys is a rocker cover gasket on a g40 the same as a standard mk3 polo ???
Etches
You can use the standard mk3 one mate, best one is the metal one off the 6N but you ideally need a head skim to prevent oil seepage over the alternator
Kayag40
Ok mate cheers im doing the head gasket on my 40 ive gr a metal gasket for the head but need a rocker cover gasket so a standard mk3 rocker cover gasket will fit on the 40 mate ye ?
Will fit but not as good. Check the sticky at top of the page
I had a non g40 one once, was a waste of money and it just squished out the sides.
Matty!
Reviving anothe thread...
anyone know where I can get hold of a G40 Rocker Gasket?
If not whats the best 'alternative'
Ben.lopo
I used the same one it had on mine and just put a bit of silicone works fine for me
Ben.lopo
And as far as I know g40 rocker cover is same size as mk2 polo
SuperMario
Are they obsolete? I have a VW gasket in my tool box  ;D
physicsfool
vwnut
I found one for other mk2f Polo's eg. for GT engine is too thin for G40 cam cover, resulting in oil leak all over my new engine.
I got the thicker one for the G40 engine from D&A Motor factors (part number: XRK4378) at cost of £31.66, but works perfectly with no leaks or bulging.
