Author Topic: eaton fitted now radiator does not fit  (Read 3227 times)
Offline davidg40
« on: June 13, 2013, 09:42:49 pm »
Hello, i am david 25 years old from holland.
I have a 93 polo g40 with an eaton blower.
I completly rebuild my motor and fitted an eaton on it, and when i had put it back in the car the troubles began.
I found out that my stock radiator does not fit anymore.
It is a bit too high because the eaton can hit it.
Wich radiator have you fitted to solve this problem?
I hope you can help me.
Greetings david
Offline davidg40
Re: eaton fitted now radiator does not fit
« Reply #1 on: June 14, 2013, 04:16:09 pm »
Can anyone help me
« Reply #2 on: June 14, 2013, 04:40:08 pm »
you'll have to be patient.  There's not many people at all doing eaton conversions.
Would moving the position of the standard radiator not be easier than fitting something else?
Offline davidg40
« Reply #3 on: June 14, 2013, 05:09:19 pm »
I tried almost everything.
Tomorrow i will strip the radiator from his fan housing.
And then i am going to puzzle again.
A member from our dutch polo forum said i had too look here beacause there are more guys with eaton conversions in england.
He was proberbly wrong.
Non the less i hope you can still help me.
Offline youngprodigys
  • G 3URO
« Reply #4 on: June 14, 2013, 05:18:18 pm »
i fitted mine by lowering the radiator on a custom made brace- not on the original.
a few others have found a solution by tilting the radiator forward to create space or using a slimline fan like pacet or kenlow.
here was my old setup - radiator is out of sight lower down
Offline sparkz786
« Reply #5 on: June 14, 2013, 07:29:36 pm »
i have the eaton conversion not done by me, was on the car when i bought it, and the radiator used looks to be a slimmer one with a really slimline radiator on it. but it was held on with tie wraps which im trying to rectify now :/ seems to be a bit of a ballache if im honest :/
Offline GR40
« Reply #6 on: June 14, 2013, 10:29:18 pm »
I had a similar problem with you when I fitted my eaton! The way I solved it was I cut and extented the hoses and moved the radiator a bit further front, just enough to clear the charger, really easy to do!
Offline vwmk3jon
« Reply #7 on: June 15, 2013, 09:00:49 am »
Mine was moved slightly further forward, almost sat touching the intercooler.
Very possible to do with a standard rad, just abit of an arse!
Offline vee-dub90
    • Facebook
« Reply #8 on: June 15, 2013, 12:30:21 pm »
mine was moved over slightly to the right and im sure it was a gt rad as it looks pretty small, stock hoses too
Offline vwmk3jon
« Reply #9 on: June 15, 2013, 04:18:45 pm »
Ive got some pics of mine. Can post them up if theyre any use?
Offline davidg40
« Reply #10 on: June 15, 2013, 04:46:29 pm »
If you would do that.
They could provide usefull info.
Offline davidg40
« Reply #11 on: June 15, 2013, 05:01:58 pm »
Could anyone post some pictures of the brackets that they used.
I think they are part of the problem, that the charger is to far away from the engine.
Offline GR40
« Reply #12 on: June 17, 2013, 09:15:33 am »
I hope these can help u! This is how I fitted my eaton! Slightly forward radiator and a bit turned and used the original intercooler but reversed the flow to it!
