Polo G40 Coupe, White, 207k, £1700 fresh MOT & Tax
Started by DKnight, June 10, 2013, 08:09:23 PM
DKnight
Polo G40 For sale
Here for sale is a G40 i picked up, had the intention of keeping it for a while and using as a second car but something needs to fund my kitchen.
Spec below:
MOT May 14th 2014
Tax 11/2013
Mileage - 207k
Standard car apart from smaller chip and pulley, dewedged throttle body.
Standard Charger
Boost gauge fitted
Legal pressed plates
Longlife stainless exhaust system, which gives a nice purr
40mm lowering kit fitted
Armour door plates fitted
I picked the car up a few weeks back and have carried out the following work:
New Timing Belt & Water Pump
New front tyres, done 3 miles so far
New rear shocks height adjustable
New rear drums and bearings
New track control arms (standard ones)
New steering rod end
New manifold gasket and studs fitted
just been tracked and aligned
10mm axle spacers fitted on each side on the rear
Top Mounts and Nuts
These parts/work alone come to just over £300
I have given the car a good t cut and polish and it has come up lovely, bumpers arches back to black with no signs of grey.
I bought this car expecting it to be a shed, with 207k miles, but it comes with a folder full of history from the original owner and it has been well looked after.
This shows in how the car drives, i have compression tested each cylinder and they all came back consistent and of a good level.
The car pulls like a train, i highly recommend coming for a test drive.
I have removed the door cards and refitted everything as it should so they have the plastic sheets fitted and is all water tight.
Both wing mirrors are tight and work fine.
Now on to the bad bits, the car has done 207k and it is showing in the bodywork and interior.
The pictures make it look really good but points to note:
both front wings have matching dents in, you can see them on the photos, i know these would easily come out with removing the wings and a little rap of a rubber hammer, they have not marked the paint.
Same goes for the rear quarter, a smaller sized dent, but no paint removal.
on the drivers side is a slight scuff/key mark, but very minimal.
Drivers wheel arch looks damaged at the bottom, but hardily noticeable.
Tailgate has a slight dent by the g40 badge
Passenger side has a really nasty rust patch to the rear of the rear window, i have cleaned this up as best i can but it could do with a better clean up.
There are a few knocks and marks so again i highly recommend a viewing to make sure you know what you are getting.
The sunroof arms are rusted and i am trying to locate some more, but at the minute it is sold without any.
Bonnet has a little mark dent in the corner, and a few other marks, but nothing major.
The interior is not too bad, drivers seat cushion is a bit warn but not warn the material away.
Rear seat has a slight patch on top section coming away, a simple stitch will fix this.
All in all this car is still in great condition, it has all the bits you would expect to do when buying a new car already done. It is all set and ready to go.
I think that is it for now, any questions please ask
£1700
Located Huddersfield
http://imageshack.us/g/1/10189449/
DKnight
still for sale, been driving this around for the last 2 weeks, enjoying being back in the seat of a G40! Really nice car to drive
benjfrst
Hi Dknight
Do you have a phone number I can call you on, I am very interested in this car
Ben
