Now sold
Started by TOMG40, June 10, 2013, 12:21:24 PM
TOMG40
ORIGINALLY 1993 G40 REG K336UNH I HAVE RECENTLY RE-SHELLED IT IN TO THIS 1LITRE COUPE BODY STILL 1LITRE ON LOG BOOK SO CHEAP TO INSURE. EVERYTHING IS G40 RUNNING GEAR ENGINE,TRANS FULL WIRING LOOM AND DASH INCLUDING THE CLOCKS THAT MATCH THE ENGINE i SWAPPED ALL THE FRONT SUSPENSION AND BRAKES AND THE G40 REAR BEAM. IT HAS FULL SERVICE HISTORY AND HAS RECENTLY HAD A FULL SERVICE AND I CHANGE THE OIL EVERY FIVE THOUSAND. I HAVE ALL THE PAPER WORK FROM THE ORIGINAL CAR HAND BOOK, SERVICE HISTORY AND LOADS OF INVOICES. IN THE LAST YEAR IT HAS HAD WATER PUMP TIMING BELT COOLANT CHANGE, NEW THERMOSTAT AND THERMOSTAT HOUSING. IT HASN'T BEEN TUNED OR MAJORLY MODIFIED I HAVE DONE BOOST RETURN MOD AND ADDED A COLD AIR FEED THAT'S ABOUT IT REALLY I STILL HAVE ALL THE PIPE WORK IF YOU WANTED TO PUT IT BACK TO NORMAL. BOTH FRONT TIRES WHERE CHANGED ABOUT THREE THOUSAND MILES AGO THERE KHUMOS. THE BODYWORK IS REALLY CLEAN FOR ITS AGE THERE IS A SMALL RUST BUBBLE ON N/S/F WING. THE INTERIOR IS VERY CLEAN NO RIPS OR STAINS THE BLOWERS WORK ON EVERY SPEED AND GET WORM TOO. UNDERNEATH IS CLEAN WITH NO RUST OR OIL LEAKS. IT DRIVES REALLY WELL AND PULLS WELL IN EVERY GEAR THE CHARGER SOUNDS GOOD AND BOOSTS WELL. I THINK IT IS PROBABLY DUE A SERVICE IT WAS LAST DONE BY JABBA SPORT. I'LL DIG OUT THE INVOICE TO LET YOU KNOW WHEN IT WAS LAST DONE. I HAVE HAD THE ORIGINAL G40 FOR THE PAST TWO YEARS AND DECIDED TO STRIP THE SHELL FOR PAINT BUT THE MORE I STRIPPED THE WORSE IT GOT SO I FOUND THIS CLEAN 1LITRE COUPE AND SWAPPED EVERYTHING THE ORIGINAL SHELL JUST WASN'T WORTH IT SADLY. I AM LOOKING FOR £1900 OPEN TO OFFERS SENSIBLE ONES ANY QUESTIONS JUST ASK OR TXT CALL 07870399596 THANKS TOM. LOCATED IN CARDIFF NEAR J33 M4.
